When I turn on my TV the picture will scramble seemingly after it warms up. Then I have to wait a couple days for it to work again just for the same cycle of scrambling to repeat itself. What part do I need to replace?
SOURCE: w2606c picture scrambled
Um...well when mine does that i unplug it and hold the power button for ten seconds and then plug it back in. Always works for me ;-) hope it works for u.
SOURCE: picture is scrambled in boxes
It means defective CRT.
Best to dispose of it properly at an ewaste facility you trust.
Az.
SOURCE: - Picture scrambled when set is
The TV has a bad board. It's called the Hyper board. It has been discontinued by Toshiba years ago so it is not an option to replace it. There are some TV repair shops that can rebuild this board by replacing most or all of the capacitors in it. You may want to call your local shop and see if they can do.
SOURCE: TV picture scrambles after about 45 mins of viewing
sounds like a lcd controller card. Replace it
SOURCE: Samsung LCD TV: Recently the picture on all
just check for your cable it might just loosed try to tighten it.
