SOURCE: amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
SOURCE: Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
SOURCE: Amana Air Command 80 horizontal central heating
Hello, I feel your pain as I have busted many of the reducilous tabs myself.You will win the lottery before You get replacements.I use to drill a new hole and install a screw to secure the door.Duct tape works but does not last.
