SOURCE: English language support on laptop with German Keyboard
The easiest solution will be to locate a replacement laptop keyboard for that model. they arent hard to replace and usually cost between $40 and $80. I would web search HP Spare parts Third party is usually cheaper. Keyboards are pretty common replacements on laptops due to wear an tear. Most are replaced using a small phillips screwdriver. Its likley you can find removal instructions on the web as well (if they dont come packaged with the keyboard.
SOURCE: i want inital webcam setup please ive got cyberlink youcam ok tha
Hello there
I understand that you want to install the web cam drivers on your dv6000z Notebook.
The web cam drivers can be downloaded from the following site.Click or copy and paste it in the address bar of a web browser.
ftp://ftp.hp.com/pub/softpaq/sp34501-35000/sp34746.exe
SOURCE: cyberlink youcam avatar feature doesn't work
You will find U cam under SP38761 on the hp website - download it and save it to a folder in your my doc's. Then you've got it OK
Glenn
SOURCE: My laptop had Cyberlink Youcam installed and the
Try deleting your cache file and if that doesn't work, uninstall, reboot, and reinstall.
