After watching a VCR tape, the unit rewound and ejected the tape. The display screen then went to a row of dim hyphens and the unit would not accept a tape or DVD, or respond in any way to selections made by either the remote or on the unit itself. I unplugged the unit and moved it for easier access and now it won't come on at all. Any suggestions or ideas as to what the problem is and whether or not it's worth fixing?
SOURCE: Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
SOURCE: No clock display
plug out the DVD/VCR and let it stand for about 2days and see what it does.if that does not work,then call a tech to look at it.good luck.
SOURCE: VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
SOURCE: FINALIZING DVD+R DUBBED FROM VHS TAPES
The manual gives you incorrect info.
To FINALIZE disk:
1. Press [HOME] button;
2. select [SETUP].
3. Scroll down to DVD ICON and SELECT
4. Select [FINALIZE]
Perfect Answer provided by "petoNOVY" - THIS ANSWER ALSO APPLIES TO ZENITH XBR616 - I struggled for 2 years to find it!!! THANKS!!!
