The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
head lock lever carefully until you hear a click.
*MP800R shown
Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sI have tried replacing all ink cartridges with bra - 05sj00142_01_en.gifnk tanks one by one.
Caution: Do not touch the print heI have tried replacing all ink cartridges with bra - mp_500_ph_contacts.jpg1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
SOURCE: Canon Pixma IP600D - error code 6502
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
SOURCE: Ink Tank not recognized
If a brand new ink tank is not recognized, it has a faulty chip. I took the chip off the faulty tank and replaced it with another one. That worked for me.
SOURCE: MP500 ink tank cannot be recognized error U043
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
11111111
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
SOURCE: canon mx310 wont print
Dear Sir, Thank you for answering. I phoned my comp. expert.He took the canon printer, as well as the previous canon printer, ( one which I used for about six months when it decided not to print) and I hope he can fix at least one of them before end of day.
Usually, and because of deadlines, etc. I pop out and buy a new one which is easier and faster and sometimes cheaper. I like to work real hard and I have to, but, I hate battling for hours on end with stuff that refuses to talk back to me. Now you can also see that I am a BBC baby.
Born Before Computers etc. and no patience.
Kind regards,
Wiebre
