Kenmore 24032\24036 Top Load Washer Logo
Posted on Dec 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 80 series 110 washer making loud noise during final spin
Kenmore top loader washer has been making a loud rumbling noise as the spin cycle concludes. All else is normal--machine still works.
  • Anonymous Dec 29, 2008
    I have a Kenmore 80 series washer. Durring the spin cycle the drum flops around and beats on the sides and sounds like its going to come apart. How do I fix it.
Anonymous
Level 2:
  • Expert 242 Answers
  • Posted on Dec 30, 2008
Anonymous
Expert
Level 2:
Answers
242
Questions
Helped
76004
Points
781
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
1helpful
2answers
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
I have a Kenmore series 80 washer that is making a loud clunking
check the motor coupler between the gearcase and motor for wear. If it is cracked or broken it will need to be replaced
3helpful
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
1helpful
Kenmore series 80 washer makes loud knocking noise during spin cycle
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
1helpful
Alexander
vince
