Water constantly draining and not making much ice
If water is constantly draining first thing to check is the water dump solenoid. There is a button on the front of the control panel that is marked clean or purge I believe. This energizes a valve to dump water out of the trough when manually cleaning the unit. This valve also energizes automatically when the unit is in harvest. Since minerals are heavy and don't freeze they will build up in the trough. This water dump helps empty out the trough and keep minerals from building up in the unit. I have seen these valves get small debris jammed in them and constantly bleed water out. If that is the case you DO NOT want to plug the line to keep it from draining you want to replace the valve. I can not stress this enough. Mineral build up WILL tear this machine down over a short amount of time.
What is the ambient air temperature in the location it is installed??
