Vizio GV47LF Television Logo
Posted on Aug 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No picture on intermittent basis -
Was watching and suddenly picture went off > vertical lines > black screen. When I try to turn on again get grey screen (no Picture) which then goes to darker screen (with minimal light) and stays like that until I turn set off. On occasion (seldom and unpredictable) I turn on and get ICON then flickering picture which sometimes clears and may stay on for hours but then goes to the "black screen of death"
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 29, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292252
Points
3377
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
5 Related Answers
Anonymous
  • 155 Answers
  • Posted on Oct 26, 2008
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Anonymous
  • 2985 Answers
  • Posted on Oct 20, 2007
SOURCE: Half of the screen is black and doesn't display the picture
Send it back this appears to be a major failure
SALMAN NASEER
  • 1011 Answers
  • Posted on Jul 29, 2008
SOURCE: my tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Anonymous
  • Posted on Nov 02, 2009
SOURCE: Vizio 50 inch plasma tv has no picture and no
check the Y-sus and Z-sus board
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 29, 2010
SOURCE: TV looses picture and sound. Will not turn back on
www.plasma-television-repair.com/Sample-Preview-Plasma-Tv-Repair-Training-Manual.pdf -
Above is a training manual, this should help you find and fix the problem if you wish to DIY. If you DO, decide to DIY, you MUST MUST get a Service Manual, for your exact make & model. it will be similar to the Training manual, but explicitly for your set. I do not recommend it however.In my professional opinion, you should contact Vizio and ask for an approved local service center, then, get a "Quote" for repair.
With faults such as this, it is important to leave them disconnected from the wall, as it is entirely possible, for a faulty, TV, to cause a fire, an explosion, or both. Anytime one hears any sort of "pop" similar or not, is grave cause for concern, as usually this means some sort of component failure, in a high voltage area.
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Screen went black with a couple vertical colored lines
Check the tcons connections ( both flex cables and also the LVDS cable) if that doesnt solve it would suspect the Tcon as being defective. For further assistance please respond to this same post.
Sanyo DP46848 LCD TV has black screen with colored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
I have a Sony KV-27S36 purchased mid to late 90's. I suddenly have sound but no picture. At first, I could get a picture by turning it off and on and letting it warm up, now I cannot even do that. ...
yap! That sound vertical problem! just solder all old parts in vertical section and check yoke if have mold? Check all looking old's electrolytic capacitors and change that if nothing happened tha'ts the time to change vertical IC.
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
2answers
Rainbow vertical lines going up and down the screen, no picture
thanks no further assistance needed from you--ta ta.
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
