I have made a mail merge to print envelopes. Where do I put the envelopes for printing?
SOURCE: Trouble printing envelopes
Instead of Word 2000 use Corel Draw for printing invelope. Because there are too many options for placing your text at desired position.
SOURCE: mail merge tri fold printing
We fought this same issue.
This should solve your problem.
In the print dialog button, select pages 1-x rather than ALL, or edit the registry to define a batch size of one instead of 10. This solution should be valid for all copiers with collate, staple, or fold finishing capabilities. See instructions here:
http://support.microsoft.com/kb/891904/en-us
SOURCE: Can't Print Envelopes from the Bypass Tray
you have to tell the printer in the print que that you are using envelopes and what size envelope.
-Carl, please let me know if this helps.
SOURCE: how do i print envelopes on a Lanier LP331cn laser
You should see a bypass tray near the main paper tray. On laniers it is recommended you use the bypass tray for envelopes.
when you send a print job make sure to select the bypass paper tray option
