How old is my kenmore dishwasher Model number 665.1633
SOURCE: Dishwasher doesn't drain fully
Some model 665 DW have a check valve that is attached between the sump and drain hose that may have a blockage..... Remove the drain hose from the long plastic valve then carefully unscrew the check valve from the sump. Inspect for debris.
SOURCE: Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
SOURCE: How can I determine what model number my kenmore
The model number may be on a label located in the door jamb, probably along the top. If not try removing the lower panel (below the door.) You may find a placard there.
SOURCE: Trying to determine its age
Only from the manufacturer you can find. If you can note the Model No Sr. No of the machine, it is possible. If it is a discontinued model, it may not be possible.
