I have a new macbook pro. Can I download a driver for Paperport Deluxe 9 that will work with my Xerox documate?
Hello.
I am a Support Engineer with Xerox Scanners.
The PaperPort Software that comes with DocuMate scanners is only for PCs. As you may know, many Mac users run Windows inside their Mac OS using various different brands of software to achieve compatibility with various different PC only software packages. If you search the internet for "Run Windows on Mac" you will find lots of options available.
We also offer 2 scanners that have Mac compatible software included. The Xerox DocuMate 3220 and the Xerox DocuMate 3115 can both scan directly to PDF files without having to install Windows on your Mac. The Xerox Mobile Scanner is a driverless scanner that can scan to a USB flash drive, SD card, or the Wi-Fi enabled Eye-Fi SD card.
If you continue to experience trouble or have any questions, please feel free to contact us by
calling 800-648-0410.
Regards,
Xerox Scanners Support
Hello.
Regards,
Yes u can
SOURCE: I Need Serial Number for ScanSoft PaperPort Deluxe 9 for PC
use one of these... 6809A-G00-591837 6809A-G00-591837
SOURCE: issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
SOURCE: Describe your scansoft paperport deluxe 9 windows
Hi there and welcome here
Take a look here :
http://reviews.cnet.com/document-management/scansoft-paperport-deluxe-v/1707-3522_7-30787056.html
It does not describe windows Vista, so I think it is not compatible with windows Vista, so there is 2 thing you can do :
1. you can see if it runs in compatibility mode, and you do it in this way : Highlight the program icon on the desktop or in the start folder, choose properties, select the last tab, choose compatibility mode with windows xp and try to open the program
2. If it is not working maybe you can upgrade to a newer version, for that you have to go to the product homepage . Normally you find a link in the program where you can go to the product homepage.
Hope this can help
Have a nice Christmas over there
Please rate my answer
