Thomson 20LCDB03B 20 in. Television Logo
Anonymous Posted on Aug 27, 2012
Thomson 32wb842s stays in standby mode can i plz have service manual as there is no workshop in karachi pakistan who can solve problem in this tv plz help. b4 this broblem the picture was cut from top
Thomson 32wb842s in standby mode please note my e mail address pervaizhussain3@hotmail .com i shall be ever grateful thanks
Anonymous
Level 3:
Top Expert:
  • Thomson Master 14,553 Answers
  • Posted on Aug 27, 2012
Anonymous
Thomson Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2714879
Points
48227
There will be no service manual as thompson does not provide them.-Its a throwaway set.
4 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on May 24, 2010
SOURCE: My Thomson TV does not turn on.
http://elektrotanya.com/thomson_20lb020s4_23lb020s4_30lb020s4_ch_lcd02tc_sm.pdf/download.html
here is your service manual. Well, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Thomson in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
COLIN
  • 182 Answers
  • Posted on Jun 03, 2010
SOURCE: MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
Anonymous
  • Posted on Jul 23, 2010
SOURCE: Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Anonymous
  • 17 Answers
  • Posted on Jan 19, 2011
SOURCE: my thomson projection tv serial
This sounds like the protection circuit operating. With projection TV's, the cooling fan is essential to prevent damage from overheating. The fan contains a pulse generator to indicate rotation. If the pulse stops, the protection circuit will turn off the set. 5 minutes may be how long the fan takes to seize when it warms up. Also possibly heat sensitve parts along the cooling path covered with dust causing heat sensors to operate.
I want connecting cable for transfer my video in pc,plz arrange this to me
Most often requires a simple cable. Many available at Walmart or Target etc.
http://www.pccables.com/cgi-bin/orders6.cgi?action=CameraFinder&rsite=g.cam5&gclid=Cj0KEQjwqe-rBRCv_J6qs6isp6EBEiQAmbctFgFJzzY5FC49CW-UvjgU85OH4_51FG4Varvb8uIPFQgaAjVT8P8HAQ
This LCD TV was purchased from Best Electronics RIYADH Saudi Arabia in Oct.2010. Booked in its original packing through shipping cargo to Karachi Pakistan. When opened and checked it was apparently OK. But...
Just contact the shipping company and ask them to get it repaired or replaced. They have insurance for this sort of thing. It was their mishandling after all that caused it. The repair cost will outweight the replacement cost in a repair like this.
Hope that helps.
2answers
Lcd tv repair service center in Karachi
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
Toshiba.com
I hope this helps.
6helpful
2answers
I have a LCD TV THOMSON 32lb040s5, the problem is that the TV start and turn off again and again when I start it
you probably have a fault on the stand by power board.
this normally requires soldering and maybe some componet changes. This is not a job for the unskilled. best carried out by a service engineer(shock hazard)
there is a service kit for this available from tvs-services.com 012453925
Tv wont turn on
well first of all if anything happens when you push the button then the button works! I think you should leave this one to a professional technician. There is a circuit problem that will require advanced knowledge.
Thomson 32WZ610s television stays in standby
It the power inverter supply board 90% of the times.Very comon with LCD tv's design flaws in power inverter boards.Many,not all use the
same designs.
RED TINT
yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
HI, TV Thomson Black DIVA
how to known the service mode for thomson tv blackdiva
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
