SMy devices detect the router(rt n10), but can't connect to it's wi-fi
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address
SOURCE: I am usuing a Speed
The correct way to connect a router is to connect the computer on one of the ports first ...(1st one) (via lan port )..and after that type the routers ip address in the browser of the computer ..like this ...http://192.168.1.1 or the IP address that it is written on the back ...
after that it will show you the setting page of the router ..and ask for a name and password...
For assus the name is admin and the password admin on the factory settings ...
if you do not have it new ..and was used by another one ...you have to reset router first .It has a reset button hidden in a hole in the back ..that need to be pressed for about 30 seconds ...Be sure that it is powered and on when you do so ..
After you get by the admin and password screen ..you get into the settings ..and in there set the connection for the wlan port ..where you should connect the modem ..to get the router access to the network ..
here choose to get an automatic Ip if this is the way your modem works ..or use to assign the following Ip addresses..and insert you network data..
in this moment you will choose a range of IP addresses that will be used by the router for the ports ..and the computer will be set on the tcp/ip of the lan card to get an IP address automatically ..and the router will provide one for each port in the range you selected..
after you completed all these ..the router should be already connected to the internet..and all that you have to do is set the wireless channel ...and enable it ...and choose a name and a protocol fr password if you need one ..but if you do not have anyone around in a range of 100 m you do not need it ..cause it will not be able to connect ..
Another issue that you need to keep in mind is that sometimes the modems and the router came from the factory with the same IP address and in this case you wil have to change the IP address in the router to not get in conflict with the modem ..
this can be also changed from the settings like all the rest ..
SOURCE: well i have a rt-n 10 wirless router an my
Here is a great tutorial to Connect and troubleshhot your Xbox to a wireless network.
If you need more help post back!
Thumbs and testimonial are welcome!
SOURCE: Hi I am using ASUS router
My asus rtg32 wifi wireless router is not getting connected to net. It shows connected (router with laptop) but its not connecting to net. I am not able to openany site. I m using BSNL connection. It shows no internet access.\r\n
Please suggest me what to do, what procedure to follow. Mine is windows 7 , 32bit OS
thx
shubham
shubhamformeATgmail.com
SOURCE: when i try connecting my
try reinstalling the router then it would ask you for a new network key
SOURCE: We have just bought an
Hi
You have to get the IP address of your internet service provide and once you type this IP address to the address bar. It will go you to menu set up of the router and set it up there. The encode the new password set up.
