Question about Refrigerators
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
Small clear plastic retangular part, about 4 inches long, came off the back side of cold water button, found loose, inside floor of cooler box. button still springs out after being pushed in. cooler will not release any cold water. hot water side still works. from backside of cooler, i can see a part attached to the hot water button the looks like the loose part i found from the cold button.can i find this part and replace it?
  • 3 more comments
  • ljcorby Jun 22, 2017
    where is the answer?
    I too have the same issue, but there seems to be a metal piece that I can't find anywhere that holds this plastic piece onto the piston type thing that rotates and pulls the piston out when pushing the cold button. I can't find this piece anywhere inside the unit. Thoughts?
  • AccidentalRepairman
    AccidentalRepairman Jan 22, 2019
    Actually, it looks like the clear plastic rectangular piece (mine is just shy of 2" long) is held on by two tiny plastic prongs, both of which were broken off of mine. The prongs fit on either side of the white round piston thing (photos below, you can see the notches on the nipple where the clear plastic thing fits on). When the water button is pushed it hits the top of the clear plastic part and pushes it so that the bottom of it pulls out the nipple of the white round piston thing and dispenses the water.
    I have called Whirlpool and they do not make any parts for this cooler and say it is not repairable. Their advice is to throw it away and buy another one, despite the fact that it is a five cent part that needs replacement. So, I ended up attaching a couple of tiny screws (#4 with a random small nut used as a spacer) on each side of the plastic part to approximate the prongs. To do this I drilled a hole on each side of the plastic part just large enough to allow the screws to be screwed in securely to the plastic. Then I screwed them in only partially. Because in order to get it on you pretty much have to position it correctly on the nipple and *then* screw the screws the rest of the way in. This requires a small offset screwdriver.
    A couple of notes: Before doing anything else, unplug the machine! The back grill doesn't come completely off as far as I can tell, so once you remove the screws gently move it over to the side. It's a very tight space inside, it helps to have small hands. Only the cold is accessible, the hot is behind the tank so I'm not sure it's possible to get to that side (but you can kind of see it, if it's your cold button that's broken have someone push in the hot button while you look from the back so you can see how it's supposed to work when the button is pushed).
    Photos: clear plastic part after the tiny prongs have been glued back on (so you can see how the original part looked. I removed the glued on prongs to drill the holes and replaced them with #4 screws), and the white piston showing notches in the nipple where the clear plastic part attaches.
    AccidentalRepairman Jan 23, 2019
    Photos of the rebuilt part and the part reinstalled.
    Sergeant:
  • 177 Answers
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Posted on Aug 27, 2012
    what kind of answer is this to the question above? Really?
    Actual answer is in comments above.
HVACRH20
  • 237 Answers
SOURCE: Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Posted on Nov 10, 2006
garing
  • 998 Answers
SOURCE: Freezer Working Frig not getting cold enough at max setting
unplug 24 hrs with doors open plug in again if it works better you have a defrost problem. it may be the defrost termination switch.. burned out element or bad timer
Posted on Aug 03, 2009
SOURCE: water not getting cold
how do you check the compressor?
Posted on Jul 18, 2008
tborn6
  • 700 Answers
SOURCE: Water line compression fitting not working
there should be a insert that goes into the water line at the end after the compresstion fitting is slid onto the tubing. you call allways take and go to ath eharware store and get a new compresston coupling for this situation.
Posted on Dec 22, 2008
SOURCE: sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Posted on May 05, 2009
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
Temperature on a whirlpool D10 watercooler
Lisa coolers similar to yours=> Whirlpool Dual-Temp Top-Loading Water Cooler
It appears that customers gave a not so good review yet being inexpensive this is common when most products are imported from China. The WHKM-D10 that you have now is now called the WHKM-10DP Whirlpool Dual-Temp Top-Loading Water Cooler with Heated Water. Wish I had better news, but please keep me in mind for any other Whirlpool, Maytag, Kitchenaid, Jenn-Air, Amana,or GE Home Appliances, Thanks, John Tripp/AKA Sea Breeze
http://appliance911seabreeze.com/
Whirlpool Factory Technician
You also can find a user manual by clicking here=> Whirlpool Product Literature; Manuals, Guides and Instructions
Nov 15, 2011 | Refrigerators
I just want to know how to hook up the water lines for the water and the ice.
there should be a small 1/4 inch to 1/2 inch clear plastic hose coming from the back of the unit, in the house there should be a small water valve similar to the one that turns on your toilet, just hook the two together (may require hose clamps and tools depending on the setup) simple as that
Aug 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Disconnecting the waterline
Hi, If you remove the grille below the doors, you can see a plastic water line passing through the lower hinge. Follow the line back about 6 inches and there should be a quick disconnect. It may be a screw type or the kind that you push down a small ring to get it to release
Apr 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My battery is flat and can not get into the boot as the boot release is lock ??
Remove plastic panel right of acc pedal
You will see fuse panel.Look for red retangular block,not a fuse
Pull out fully,if tight use small screwdriver carefull not to damage fuses
Once pulled out on the top you will see a metal strip
Connect jump leads/booster + to this, connect - earth to door latch on inner door jam
Now press button to release boot/hood.
Jan 23, 2010 | 2001 Porsche Boxster
Plumbing in fridge/freezer
That is the water inlet for the ice maker. It is 1/4 inch diameter and will need to connect to a valve of that size with 1/4 inch plastic or copper tubing.
Please rate if this helps-
Mar 23, 2009 | Whirlpool Home
How to remove water filter on Whirlpool ED2VHEXVQ00
the filter is located in the front of the unit just below the freezer door whirlppol has 2 filter options one has a push button next to the round filter cartridge that whne pushed releases the filter. the other option is a twist out filter simply turn 1/4 tun counter cloclkwise and the filter will come right out.
after replacing filter run aprox 1/2 gal of water to clear air and remember to reset filter monitor according to your owners manual
Jan 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Cleaning solution
buy a new solution tank. the problem might be that your not rinsing the tank with clear water after use and the soap hardens on the release button of the tank.
Feb 08, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Refrigerators Logo
1,647 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
