E13 code, monitor 2400
I have a mpi monitor 2400, and the e13 code is always showing up. what does this mean? how do i fix it?
  • boatandfi359 Jan 17, 2009
    Did you ever get an answer.
  • 3 Answers
You have an obstruction in your fuel line. Lint or rust or some other debris, either in your main fuel filter which I hope you have or in the small one in the fuel sump on the lower right hand side (the little square hole below the round finger hole for the reset button). The screen is cleanable with air or brakekleen or both. Or it might be that your Constant Level Valve is tripping or has tripped. Push the button in the round hole on the lower right hand one time quickly (don't hold it down or press it several times slowly) and you should hear the float drop. Fuel should resume flowing to the fuel sump at that time.
Posted on Nov 03, 2009
6ya staff
SOURCE:
Solving e13 message on a mpi 2400 monitor
Sep 26, 2018 | Heating & Cooling
Monitor MPI it flashes F 13 or 14 & smells, I had it cleaned 6 months ago
The codes are "E" Codes. an E13 is no fuel. E-14 means flame rod malfunction. Unplug the heater then reconnect, this will reset the heater. Try your red prime button. Could also be the fuel pump or your fuel source feed line isn't flowing fuel.
Feb 17, 2016 | Heating & Cooling
Monitor heater 2400 turned off with code E13, what does that mean?
This is an over heated indicator, what make and model unit.
Apr 04, 2015 | Heating & Cooling
How to fix a mpi 2400 with a e13 code how to fix
You need to have the system cleaned up.
Nov 18, 2014 | Heating & Cooling
E-14 code mpi monitor 2400
It sounds like you have a fuel problem, check to see if there is some kind of blockage in the line or at the tank value.
Jan 25, 2013 | Rinnai Toyostove Direct Vent Heater: Laser...
Monitor 2400 Kerosene heater service
Check your filter in the fuel line outside if you have one. Also check the strainer in the fuel sump.
Feb 02, 2010 | Heating & Cooling
E13 keeps blinking on my monitor 2400 heater
causes of E13 error code:
Failure of ignitor, solenoid pump
or circuit board.
Incorrect wiring or flame rod
touches to burner parts.
Air pressure switch or overheat
open
I recommend taking it to a qualified service center.
Unfortunately, this can be a hard problem to trace with some experience and equipment.
Hope that helps!
-Helping Hands Services-
_Fairbanks, Alaska_
Nov 21, 2009 | Heating & Cooling
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
4,390 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
