Use lithium (non-rechargeable) high energy batteries for best results. This is clearly a power supply problem. If it doesn't work, send it back for replacement. If the batteries are self-contained, ensure they are fully charged using the charger supplied with the camera. Remember, rechargeable batteries are only good for a maximum of two years. Cameras, in general, do not work well with rechargeable batteries as the voltage is less, i.e.; 1.25 volts vs. 1.5 volts per AAA/AA/C or D size battery.
SOURCE: Bushnell Trail Sentry Camera- forgot password
Trail Scout and Trail Sentry camera re-programming procedure.
1) Turn unit on and wait for screen to prompt password
2) Press the enter button and hold until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry cameras will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
3) Press enter to confirm 5 digit mode (for trail scouts go to next procedure).
4) Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th 0ne is entered in the _ _ _ _ screen.
5) Camera will now go into operating mode, and user can now program a new password from the setup mode
SOURCE: Bushnell Trail Sentry Digital Trail Camera
To reset the password:
Turn unit on and wait for password prompt
Depress the and hold the enter button until camera
Trail sentry systems will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th digit is entered in the _ _ _ _ screen.
SOURCE: forgot password on bushnell trail sentry game camera
If the Bushnell Trail Sentry 11-9200 is turned on without an SD card in place, it may need to be reset. Reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Read this Set Up Guide for instruction how to set up your passcode.
If you are looking for a replacement trail camera, or you want to buy another, go to my Hunting Supplies Website and browse through the different name brands offered for sale here. http://hunting-supplies-net.com/
SOURCE: I got my Bushnell Trail Sentry Digital Trail
the first time the camera is used the code should be 0000 unless previously changed,try removing and reinstalling the batteries,this hould start your set up again.
press and release the power button and wait for 4 H's,"HHHH" to appear,this may give you another chance to use 0000 or whatever you chose as your password.press enter after each digit,then press enter again.the indicator should display PASS.if it displays ERRO then it is the wrong password.there is a password recovery service provided by Bushnell at 1-800-423-3537 and press option 2,you will need to provide your serial number to the representative.
hope this helps.
