orange blink on ethernet means that your connection speed is 10Mbps,and green blink means 100 Mbps there's nothing wrong with itorange blink on ethernet means that your connection speed is 10Mbps,and green blink means 100 Mbps there's nothing wrong with it
orange blinking means your connection speed is 10 Mbps,and green blink means 100 Mbps there's nothing wrong with itorange blinking means your connection speed is 10 Mbps,and green blink means 100 Mbps there's nothing wrong with it
You can't post conmments that contain an email address.
Troubleshoot the wired network connection
Make sure you are using an undamaged Ethernet cable, check for a green light near the Ethernet port on the printer, and then print a report to verify the connection.
Turn off the printer, and then disconnect the Ethernet cable from the router and the printer.
Check the cable for damage, and then verify that it is an Ethernet cable and not a phone cable.
NOTE: Ethernet and phone cables look similar, but Ethernet cables are usually bigger and have eight visible wires on the connector.
Reconnect the cable to a different Ethernet or LAN port on the router, and then connect the other end to the printer's Ethernet port.
Turn on the printer.
Check the lights on the printer's Ethernet port to make sure the connection is successful. The green light should be steady, and the orange activity light should blink.
Print a Wireless Network Test Results or Network Configuration report.
Inkjet printers with a control panel menu: Open the Wireless, Network Settings, or Setup menu to locate the list of available reports.
Most inkjet printers without a control panel menu: Press the Wireless and Information buttons at the same time, or press the Wireless and Start Copy Black buttons at the same time.
LaserJet printers: Press and hold the Wireless button for 10 seconds or until the Ready light blinks, or go to the Wireless menu and select Wireless Network Test.
Laser NS and Neverstop Laser printers: Press and hold the Resume and Wireless buttons for 3 seconds.
DeskJet 6000 and 6400, ENVY 6000 and 6400, and Tango printers: Touch and hold the Information button until all control panel buttons light up, and then touch the Information and Resume buttons at the same time.
Make sure the Network Status is Ready, or follow any instructions to resolve network issues identified on the report.
Step 1: Make sure the that router is connected to your modem with an ethernet cable via the router’s internet (WAN) port.
Step 2: Unplug the modem from its power source and make sure that it's totally turned OFF. Then re-plug the modem to the power source.
Step 3: Unplug your router’s power supply, wait for 10 seconds and then plug it back in. This will cause the router to reestablish communication with the modem.
If you still cannot browse the web, contact your Internet Service Provider (ISP).
Solution:
Solution:
Site reference link: https://www.belkin.com/us/support-article?articleNum=56519
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
The ASUS site has a quick start guide (I read Version 3) that says the lights show blue for connections and blink blue for activity. Sometimes orange indicates a connection at a lower speed. What happens when you try a spare port? What is connected to the 'orange' port? What do the lights at the other end of the suspect patch cable indicate? Note that the manual isn't great because the titles say Gigabit Ethernet but the text talks about 10/100 but not 1000 megabit ethernet.
This is a layer 2 device and it ain't exactly the cleverest box on the LAN. If you move devices to other ports, it is supposed to figure that out dynamically. You should be able to eliminate devices one at a time to determine which port or device is defective. Start by eliminating the 'orange' device. If the router is disconnected can you still print?
If you have limited functionality with the suspect device disconnected, the problem could be with that device. Sometimes cables can be a problem. Not likely but it is necessary to check by substituting a known good cable on a link. If the problem goes away, it was the cable.
Remember to photograph the initial configuration with your smartphone. That can help you when you forget where you started. Label the wires with masking tape if there are no other labels, so you can find your way back to the starting point.
The blinking orange power light suggests that there is a problem with your modem. The modem should be plugged into the top ethernet port of your router. Try turning off your modem for 10 seconds and then turning it back on.
If you have an internet connection using the ethernet cable but not on the wireless and there is an orange light blinking.. Try to reset the router by pressing the reset button located on the back or on the location were you can twist the stand for the router. press it for about 10secs and that will return the router on a factory settings. before u reset the router make sure to acces the configuration for the internet settings of your isp provider. if the orange light still there, try to download the latest firmware of your router on linksys site and that should fix the problem
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
