How to remove old air cabin filter and insert anew one
I just changed mine yesterday and these tips listed above were unfortunately incorrect.
Step 1 - Open the passenger door
There is a panel that has no screws on the flatside of the dashboard which faces against the closed door at the jam side. Use a body tool and pry the panel carefully exposing the inside area of the glovebox. If possible dont do this in cold weather because the tabs are plastic. Inside the panel you will see one small tab that the glove box has a 1/4 plastic clip seated in the tab.
Step 2 - Open the glove box. Remove the 3 hex screws on the top interior row of the glove box.
Step 3 - At the right and left corners of the bottom of the glove box remove the two front facing screws on the lower hinge.
Step 4- At the very bottom parallel to the floor there are two more hex screws remove those (they hold the plastic vent in place underneath the glove box. Pull the vent downward to release the tabs.
IMPORTANT: Dont forget to go back to step 1 and pull the small tab from the slot in the dashboard cover area ( Inside the panel you will see one small tab that the glove box has a 1/4 plastic clip seated in the tab)
Step 5 - Pull down on the glove box to release the clips.
Step 6 - You will see a black box inside. There are three tabs (right, top, and left) pull them individually to remove the front facing cover. Inside you will see the air filter. Remove and have airflow arrow pointed downward.
Reverse steps to reinstall. Be sure to line up the clips before pressing them back in place. Do not force them!
Good luck. I hope this helps. I did mine on the first attempt with no issues in about 10 minutes (I'm not a mechanic).
SOURCE: 2008 honda pilot cabin air filter
This solution pertains to a 2008 Honda Pilot...To replace the cabin air filter which is located on the passenger side of the vehicle behind the glove box: Open glove box and remove stored items...while sitting in the passenger seat, pull towards you on each of the two clips on the left and right side of the glove box...this will cause them to become loose and the glove box will tip out completely exposing the inside of the dashboard. (Alternately...carefully pull towards you on the top center of the glove box which will cause the left and right side stops to pull away from the edges and allow the glove box to tip out) Here it gets tricky...the box holding the cartridge for the cabin air filter is the large black box on the left side behind the glove box The filter fits in a removable tray vertically inside that box. A pressure clip at the top of the box allows the vertical cover to be removed exposing the tray with the Cabin air filter... BUT!!! There is a plastic bar an inch or so high which has been placed there by the manufacturer to prevent most from changing the filter without the service department being involved. This bar must be cut with a sharp sheetrock knife or hacksaw and discarded, (it will not be reinstalled). Then there is a flat metal bar behind the plastic bar that can be removed using an 8mm socket and a phillips screwdriver. There are 2 8mm screws and one phillips head screw on each side that must be removed in order to remove the metal bar. THEN you can remove the cover to the cabin air filter box, pull out the tray with the filter (note how the filter is in the box so the new one can be placed the same way) reinsert the tray with the new filter and replace the tray cover. All other steps to finish the job are obvious as everything is the reverse. Actually the whole process is a lot of trouble and unless you are determined to change the filter I would recommend not doing it.
SOURCE: trying to change the cabin air filter
1. Open glove box
2. Unhook elastic retainer on right side
3. Locate the two "stop tabs", one on the upper left and the other on the right side. Push both to the left to clear their stops and the glove box will swing down, allowing access to the filter cover.
This is a 2011 Buick Lacrosse CXL. The only bolts I see are under the glove box, but these don't hold the gove box in. Any more suggestions
