Broderbund PrintMaster Platinum Logo
Posted on Aug 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printmaster platinum 2012 will not open.
I used PrintMaster Platinum 2012 last month to do my newsletter but now it will not open. It says that some program is causing it to shutdown. What should I do?
Anonymous
Level 3:
  • Broderbund Master 2,878 Answers
  • Posted on Aug 27, 2012
Anonymous
Broderbund Master
Level 3:
Answers
2878
Questions
0
Helped
488022
Points
8243
Try re-installing software. For more detail on cause. Right click on My Computer > Manage > Event Viewer > Application and check errors / warnings based on source.
5 Related Answers
Anonymous
  • Posted on Dec 17, 2010
SOURCE: I installed Printmaster 2011 platinum
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
Anonymous
  • 227 Answers
  • Posted on Apr 01, 2009
SOURCE: I have the Printmaster Platinum Version17 , I cannot save to pdf files?
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
Anonymous
  • Posted on Aug 17, 2009
SOURCE: I bought Printmaster Platinum 16 and used it with
to use the printmaster
choose older programs.
then ask for it to regonise printmaster and set it to win xp
now program will work
Anonymous
  • 10406 Answers
  • Posted on Apr 10, 2010
SOURCE: Is there an instruction manual for Printmaster Platinum 2.0
Is there any PDF documents on the CD-ROM?
Is there a "help" function within the software?
Anonymous
  • 2340 Answers
  • Posted on Oct 24, 2010
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Manual for Printmaster 2012 Platinum
You can access the manual within PrintMaster 2012. Once you open PrintMaster click "HELP" on the toolbar and select "User Guide". Provided you have Adobe loaded on your computer this should bring up a pdf version of the manual. Once it has opened you can choose to save the file to another location such as your desktop so it will be easier to find when you need it.
4helpful
Will Printmaster Platinum 16 run on windows 7 I
2helpful
PMSUER.DAT message on Printmaster Platinum 15
Have a look here.
http://support.encoreusa.com/kb.asp?id=144
When I installed PrintMaster Platinum it caused Microsoft Home Pu
Uninstall Printmaster or right click on file to be opened and select open with, and in the prompt select "always open with..."
I did a 4 page newsletter and saved it. Now when I open the newsletter just one page comes up with no place to turn the page and no way to enlarge the page.
Yes you are right that the software is not doing its best.Its a failure from Printmaster Platinum 18, check out if it is under trial period, then upgrade.
Or it might be the case with Printmaster not compatible with Vista. Otherwise use a different software.
Please vote the solution.
Regards
Ellin
Printmaster platinum 18
Thanks for replying back to me.
I DID NOT fix the problem!!!! I use PrintMaster Platinum 18. I'm sorry, but I do not see paying you $10.00 (or any amount) to solve this problem.
Thanks anyway.
ubufranks
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
