The picture comes in very fuzzy with a little color but not clear at all.
SOURCE: We get sound on our sanyo, but no picture. When
Probably out of warranty?
this is an issue with either one of two things,
1) Power supply
2) Lamp 'Florecent back lighting tubes' ballest.
Depending on the service shop rates, the labor is more than the part. Call around and get some price quotes. Worth your time. These set's are still expensive?
Now if it's a 15" . Buy a new one. They are just a throw away item these days.
Blessings,
A/V Guy
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
SOURCE: What is the best way to clean the TV screen ?
1Turn off your monitor or set the background color to black so you can easily identify spots that need to be removed.
Step2Apply the distilled water to your clean, soft cloth.
Step3Wipe your LCD screen in smooth motions from left to right, going from the top of the screen to the bottom.
Step4Let the screen air dry or simply run a dry area of the cloth over the screen again.
SOURCE: Sanyo TV DP42647 No picture or sound, remote does nothing
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
cannot see anything now but a bunch of green dots all over the screen.
