Question about Broderbund PrintShop PhotoPro Deluxe for PC
I have a new computer and also my printshop2000 propublisher program.Can you advise me how I can install it with windows 7? PLEASE HELP I had an ongoing project that involved 5 years work that I ca
I have an ongoing family project that I cannot continue on my new computer with windows 7 because my printshop propublisher will not install. PLEASE HELP OR I WILL LOSE 5 YEARS WORK
  • Anonymous Mar 13, 2014
    cant install propublisher 15 on windows 7
  • Broderbund Master
  • 2,878 Answers
Win 7 will allow you run in XP mode by right clicking setup. Plus MS also has a virtual XP mode PC download, but I have not tested yet. http://www.microsoft.com/windows/virtual-pc/download.aspx
Posted on Aug 27, 2012
SOURCE:
  • 798 Answers
SOURCE: i want to remove the print-shop propublisher
Try to use revo uninstaller from here :
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Use the default settings and then delete everything it suggest.
Hope that helps
Have a nice day
Please rate my answer.
Posted on Oct 07, 2009
  • 73 Answers
SOURCE: Install Printshop V.5 on a computer using Vista
The Printshop V5 program is supposed to run with Windows 98 or Me, therefore in order to use it with Vista or XP, you should open it using Compatibility mode--> Right click on the program icon--> properties-->Compatibility--> select Windows 98 or Windows Me
Posted on Nov 02, 2008
davespcr
  • 115 Answers
SOURCE: i have an old printshop deluxe program and i am
This is one of the most common complaints with Vista - your old programs may not work. Your only solutions are to either buy a copy of Windows XP (what I would do, personally) and lose the Vista, or find a Vista-compatible version of Printshop. You can try this link, which Microsoft says it will update for free to make your old printshop compatable. If that doesn't work, there are 1000's of excellent free print programs at download.com here.
Posted on Apr 18, 2009
  • 154 Answers
SOURCE: We just got a new computer with Windows 7. We
You could try installing the version 5 on your pc. There could be a compatability issue so follow the information below if it will not install.
The Windows® Vista Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information.
Posted on Apr 01, 2010
BuzzFlewhart
  • 655 Answers
SOURCE: printshop 20 deluxe will not
Yes, it will NOT work on Vista or Windows 7. I had to upgrade to PS 23 on my computer. If you have 7 Professional or Ultimate, it is backwards compatible to accomodate older software. If you have Home Premium, it will NOT work on 7.
Good Luck.
Posted on Jan 03, 2011
I have Babylock Palette 5.0 and I want to install on windows 7/32/64bit I do not know which install upgrade to use. I have installed the orginal disk and it does not work properly. Please advise.
Ester,
You will need to upgrade to Palette 8,0 or NeXT versions that are compatible with Windows 7. I'm not sure if Palette 7 upgrade will work either. Other option, may be to get old computer with Windows XP and the right Parallel printer port with the card reader security device for Palette software to work.
Cheers,
Kelly
San Diego, CA
EmbroideryServices
May 26, 2014 | Baby Lock Esante
I got Error BIOHD8 on my HP Pavilion Desktop computer Please help as fast as possible.
How much RAM and how many bit operating system winows 7 32 bit requires min 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
Nov 24, 2012 | HP Computers & Internet
I need help to Access my Poser 7 Program that I just purchased and that I just finished installing on my Windows XP Computer. Can you please help me to gain access to my Poser 7 Program please?
If the Poser 7 program installed correctly without any error messages then to access this program then -
Click on Start - All Program and click on the Poser 7 program to start the program.
Apr 06, 2012 | Computers & Internet
I just installed an update to my System Mechanic program and now when I try to open the program a window appears telling me i must restart my computer to fininsh the update. I have restarted twice and the...
You may do the update once more and see if you are getting the same message. If so, start the computer in the safe mode and disable automatic updates and restart
Any doubts you can get the help of a certified technician through the website:
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Aug 21, 2011 | Iolo Technologies System Mechanic: Windows
I got picture package version 1.8.1 for DVD Handycam DCR DVD 805 which is not compatible to windows 7. Please advise
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Oct 10, 2010 | Sony Handycam DCR-DVD805 DVD Camcorder
I am unable to get my printshop propublisher deluxe 21 to run on windows 7.
Try Installing as Administrator, BOTH installing and "Run" the .exe as Administrator. Also try setting again both install .exe and the run .exe, in "Compatibility Mode" for XP SP2. to do this right click, .exe and select properties, then choose compatibility, mode and set there. If Win 7 on 64bit, remember to turn OFF digital driver signing, press F8 at boot time, and select at bottom of list.
Mar 24, 2010 | Computers & Internet
Cant download nero 7 to windows vista home premium
Maybe Nero 7 isn't compatible with Vista? Have you tried downloading other trial programs or any file from the Internet? If nero 7 is the only program you can download, try other versions e.g Nero 8 or later versions?
Jul 24, 2008 | Computers & Internet
Open Questions:
See all Broderbund PrintShop PhotoPro Deluxe for PC Questions
Broderbund PrintShop PhotoPro Deluxe for PC Logo
119 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
