SOURCE: Sony VPL CS5
You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
SOURCE: how to rest lamp timer vpl-es4 - reset < >
http://www.kavena.se/fileadmin/uploads/downloads/Sony/Projektorer/VPL-EX4/Protocol%20EX4.pdf
That's the link, to reset this unit, it seems you must hook, up with an RS232C cable, and "Talk" th the Projector, You simply hook up, using any terminal Program. such as, Hyperterminal. I think you need to get a manual.
http://www.nodevice.com/user_manual/sony/projectors1/vpl-es4.html
I looked but could only find, pay for links, for the service manual. You really need this if you own anything it is worth any money, as in it is the information, the the engineers that service them, use to troubleshoot and fix, special codes, and settings the lot. So it is a must have.
SOURCE: I replaced the projector lamp in my sony vpl-cx4
for resetting lamp hour do the following
press the following keys on the remote in the following order for less than 5 seconds each.
RESET then LEFT ARROW then RIGHT ARROW then ENTER
OK
SOURCE: i have a sony SVGA VPL-ES4, when i turn it on it
hi,
Do one thing try to reset the lamp hour timer. for the same do the following.
Press the following keys on the remote in the following order for less than 5 seconds each.( on standby mode)
Remember on thing lamp reset is recommended only after replacing the lamp. if works try to replace the lamp as soon as possible.
ok
