Here is the entire message.The server will not turn on. PowerEdge t300 E1000 Failsafe, call support E1229 CPU 1 VCOREE E122A CPU VTT Pwr gd I1911>3 errs Chk log
SOURCE: Dell Poweredge 1800 server
Hi the Power Supply also needs to be upgraded for the additional RAM and new CPU . Please look into this aspect. My opinion a slightly Overrated PS would be better .
SOURCE: Adding DVD to Poweredge 2600
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
SOURCE: Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
SOURCE: When powering up a Poweredge 1600sc i get 6 error
It states 1-3-2 = No memory installed
Remove and reset the memory modules (see "Memory Modules"). If the problem persists, replace the system board (see "System Board"). Good Luck
SOURCE: nic teaming on poweredge t300
NIC teaming is useless unless you have a switch that support teaming.
However, Dell servers have free lifetime phone support ((800) 945-3355).
They should be able to help.
