Question about Panasonic Viera TX-P58V10 58 in. HDTV-Ready TV
Panasonic tv will not turn on red light flashing 3 times what does it mean
    Top Expert:
  • Panasonic Master
  • 54,189 Answers
Open internal fuse or power supply failure
Posted on Nov 29, 2016
SOURCE:
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Posted on Nov 25, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
djchillsnyc
  • 152 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
SOURCE: I HAVE A PANASONIC PLASMA TV TH-50PZ80U MODEL #.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else. Anyway thats my 10c worth.
Posted on Apr 02, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
May 18, 2009 | Panasonic Televison & Video
TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
having problem with sony television the screen when its turn on no images found just found red color on the screen..
Feb 01, 2009 | Panasonic TX-42PT10 42" TV
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic Viera TX-P58V10 58 in. HDTV-Ready TV Logo
13,820 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
