If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
182
My Wii shows a " cannot read disc" then black screen, eject turn off power, consult manuel for the the Wii games. The remote does works and it will play Gamecube disc games.
either when the game is first inserted or halfway through certain games I get the black screen, error occurred message and told to turn off the power and read the manual. Why is this as its happened with brand new games???
