It is mounted on the wall, seldom used, only a year & half years old from the date of purchase. all the other appliances connected to it such as the amplifier, dvd player and subwoofer becomes contaminated with a slight electric shock. although, all the other said appliances becomes fine when i disconnect them from the tv. thank's in advance!
SOURCE: No picture No sound
how did you remove the stand attached to the tv? But i have heard of this happening before too..They tend to just die..
SOURCE: My klh subwoofer has R&L
Yes, you use a subwoofer cable and hook it into the mono rca jack in the back of the sub. or you can use a Y splitter 1 female to 2 males. or if your amp has 2 sub outputs (L&R) then use both. I do believe it's said that if you use the high level input, it's better. I forgot why...
Oh yeah. the difference between the 2 is a high level input allows the currant from the amp to pass through the sub, thus allowing the continuation of wattage to your other speakers.
Low level input is only taking a audio signal from the amp. No power is being sen through the connection.
SOURCE: amplifier turns on but not the subwoofer?
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
SOURCE: Yamaha YST-SW320 subwoofer won't play sound
I too have amplifier and speakers thatI rent for parties, and sometimes when I connect them they don't work and I battle with them for hours before I find the out that its just a little thing that happened, like speaker wire might have cut inside, or the wire conneted for the CD to Amplifier is bad and son on.
But I will advice that you test your amplifier and woofer, with another equipment independently to be sure if they still working well or not. As this will help you to know what to do next.
May somthing happened to one of them the last time you used it and you did not notice, and it might just need some servicing.
Best wishes
SOURCE: Hi. I have an old Sony Wega 32" LCD TV which I
ok it depends on the wall mount but this is the basic idea of it. make sure there is at least one other person to help you.
1. Make sure everything is off and unplugged from the tv.
2. If you have cables holding your tv to the wall remove them.
3. there should be securing screws at both sides of the arms attaching the tv to the wall. loosen them/ remove them.
4. lift and pull the tv away from the wall. have a friend help you.
5. remove the screws and bolts from the tv and the wall mount and you should be done.
If this doesn't work, find the manual for the wall mount. if you need help or additional tips put them in the comments. Thanks
Testimonial: "Thanks Thinkingmonk, you're a star."
