Question about Sony Ericsson K850i Mobile Phone
Sony ericsson w995 will not ring
The phone will only vibrate, it will NOT ring (phone is not set to silent, menu is set for phone to ring. Have tried resets and removing/replacing the battery.
  • Sony Ericsson Master
  • 14,641 Answers
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Posted on Aug 28, 2012
SOURCE:
SOURCE: No sound at all on my phone (not on silent)
I've had my phone for close on 2 yrs now so I know it quite well. Simple (and obvious) way to test if the phone rings is to ring it from a land line and listen out for the ring tone. Maybe you are not clearly hearing the ring tone from all the other noise around you- try some other ring tones that have varying notes. I downloaded some of songs I like. I found that makes it easier to hear. Don't go for rap music- I found that was the most difficult to hear. I've managed to transfer an mp3 song from my computer onto my phone and use it as a ringtone.
Another way to test the speakers is to play some music through the "entertainment" menu. That way you can test to see if the volume adjustment is working well. If you can only hear the music faintly (as well as all other sounds), then there is probably something wrong with the speaker.
Yes, mine has a green light that flashes occasionally. I think that is the phone checking the signal.
Posted on Feb 07, 2008
SOURCE: My Sony Ericsson W890i, I cant set the alarm with a vibrate tone?
You go to:
main menu->settings->sounds & alerts (or something like that)-> vibrating alert
Open this and you will find 3 choises (on,on if silent, off). Choose "ON".
Then vibrating alert will be always turned ON,even if You putt it on "silent".
Posted on Sep 05, 2009
SOURCE: sony ericsson w995 saying orignal battery is needed to charge
this is a software glitch
same thing happened to me
you must update your software with latest sony drivers for w995
go to sony ericcson update service
Posted on Oct 26, 2009
SOURCE: My Sony Ericsson K850i will NOT ring, just vibrates
I had the same problem and I reset it. It said that I would not loose the contacts and I did not, now it is ringing.
Posted on Mar 16, 2010
AldRezaine
  • 995 Answers
SOURCE: my sony ericsson w995 does not charge when i try
That only means that you got battery problem of your phone. Replace the phone battery with a new one. If your old sony ericson phone battery can be fit to your w995 then you can try to use it.
Hope this could help..
Posted on Mar 28, 2010
How to removed or turn off the vibration on the phone?
What phone you have would be useful to know but for
Android : How to Turn off Sound and Vibration in Androids Keyboard
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Blackberry:
Turning vibration on my mobile phone on or off
  1. Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
  2. Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
  3. Exit.
Nov 09, 2015 | Cell Phones
Why is my phone on silent ?
Has happened before at many of our locations, always after being dropped. Usually the phone is not on silent, the ringer is broken. The only solution we have found is top replace the handset.
Aug 22, 2014 | EnGenius DURAFON1X DuraFon 1X System Phone
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
How do I turn off silent mode on my Lg 365 as choice seems to be silent or vibrate and cannot find profiles under settings as stated in manual
The quickest way - on the left side of your phone there is a button with up and down arrows. Keep pressing the up arrow and this will raise the volume up, or keep pressing down and you can set it to vibrate or silent. Also, you can change it from the menu. Go to Menu > Settings > Audio & Ringtones > Ringtone and there are all of your options here. You can go to Volume and set the volume, Alert Type and set if you want it to vibrate/ring, etc. I hope this helps, if you still have questions feel free to ask :)
Apr 28, 2011 | LG Neon GT365 Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
When someone texts or calls me my phone vibrates instead of ring
You probably have silent mode on. Try pressing and holding the pound or the star key. One of those will probably release silent mode, so that whatever ring setting you have can be used.
Nov 09, 2009 | LG RUMOR Cellular Phone
My LG VX-8700 does not vibrate. Ring works, but vibrate mode is the same as silent mode. Can this be fixed?
Yes,
What happened is you probably set it on silent and from the soft keys, you increased the ringer volume. What you want to do is go to main menu => settings => profiles, and from there make sure your ringing volume is set on lowest possible.
Oct 28, 2009 | LG VX-8700 Cellular Phone
Hi Does anyone know if you are able to set the ringtone to silent and also the incoming message tone to silent (need it for work) on the Samsung F480 Thanks Elkay
In order to set the ring tone to silent you must turn the volume down to silent or vibrate. Go to phone in menu and check on sounds.
Jan 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Will not ring or vibrate.
Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
Jun 26, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Sony Ericsson K850i  Mobile Phone Logo
361 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
