When change a hdd , then start showing a number like error 19990305. the OS doen't work only runs the 1rs part and turn off
If your bios is loading up completely then you need to reinstall the OS with a disk. If the bios is not loading up all the way you need to go into your bios and reset it to the defaults. If you can't access the bios you need a new motherboard and unfortunately with laptops it is cheaper to but a new laptop than a replacement motherboard. You can rip out the HDD though and put it into an external enclosure to get all your old files. then once you have all your old files off of it you can format the old HDD and you have an external HDD for future back up :)
SOURCE: IBM ThinkPad 600X PC Notebook 08611 error message
nice laptop!! but, many people have this message on their IBM's, so i found i dude that said he had it but knows how to get around it. please bare in mind i dont have this laptop, so i dont guarantee good results, but its worth a try!!. here it goes :-
1.switch on your laptop
2.the screen will then display the error, 08611
3.click okay!
4.the screen will show the "stuff" in your laptop
5.click exit
6.then click configure
7.press ctrl + the letter D
8.the screen will display the commands to run your laptop
9.you go to the first and third row and change the number "02" to "01"
10.press f3
11. reboot your laptop
oh and here is where i got it from
http://mailman.linux-thinkpad.org/pipermail/linux-thinkpad/2004-February/015935.html
hope this helps!! ^^
please post to tell me the news!!
SOURCE: IBM THINKPAD 2635-5AA 380ED ERROR 174
Your problem sounds like the system isn't finding the hard disk
SOURCE: ibm thinkpad x40 keyboard problem numbers locked
The numeric lock function is on. To disable it, press and hold Shift; then press NumLk.
SOURCE: IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
SOURCE: IBM Thinkpad 600e (2645),error 189 and could not installing win98
Usually this means a hardware failure. I would suggest reseating the CMOS battery overnight to reset the system. Also you might want to replace it as well. It could also be more serious such as a motherboard component failure.
Also IBM error code # 189 according to Scott Mueller's Upgrading and Repairing PC's (8th edition) - "Excessive incorrect password attempts." Is there a password on your CMOS ?
Also try hitting ESC key on boot to bypass. Good luck!
