This is an older watch. On the back, there are the numbers 20/3063x and 2105. The watch is at least 20 years old, probably older. I need to know how to set it. There is only one setting winder--no extra buttons.
You can get instructions off this link below
http://www.armitron.com/watch_instructions.asp
Testimonial: "Exactly what we're looking for. Thanks!"
SOURCE: WATCHES
i hope this helps....
the top right says st/stp....tells you the year
the bottom right is the light...
the top left is the reset....
and the bottom left is mode...alarm, stop watch,and time 2
SOURCE: How to set armitron digital watch 45/6915?
Assume A B
C D
To turn off the alarm press & hold A then press B, do this several times until your alarm/chime is either on or off.
SOURCE: How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given
their positions relative to where numbers would be on the face of an
analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The
options appear in this order each time you press the "ST/STP" button:
minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
SOURCE: setting time on Armitron 40/ 8089
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please
SOURCE: how do i set the day of the month on my armitron 2105 blue face
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals.Rate me, please
