I need to charge my phone during the day and over night . its 12 pm and its at 48%
SOURCE: battery runs down fast.
hello there....well its quite simple...
how old is your phone ?
i am assuming its an old phone so it is time to change the battery...you will see that batter is slightly puffed or out of shape ...in that case you should immediately change it
if its a new phone....then check if blue tooth is on or off....it should be off....and if you use the phone a lot then also the batter will run out in 3 hrs and 30 minutes of talk time...playing music as well as keeping the camera on for a long time will drain the batter
so it depends on how you use it ....if you have more question we will take it from there
Hope this help
Cheers
SOURCE: battery goes down so fast. nokia n91
the problem may be one of 3
1-imagenary charging
2-bad battery
for the first one try another battery and charger
and for the second just try your battery on any phone
3- the problem in the Main board (Tahvo component)contact anyservice point
SOURCE: My Samsung Galaxy Apollo (GT
Yup I fear your battery is gone faulty.. A common thing. You will need to obtain another. as an aside here try to say charge your phone up overnight, everynight, and use it during the day, also try to do it for at least the same amount of time each time you do. This will help with battery life.
