Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
My Samsung DVD player R
135, suddenly is in strike!
It plays and music CD
but no videos DVD’s.
When a CD is inserted
it starts immediately and plays fine, When I try to play a movie (DVD) a strange
noise can be heard the DVD keeps spinning for while then the sudden note on the
screen the ‘DVD can not be played check the DVD’ and the DVD id ejected.
I have tried to set
the region free code with no luck.
Any ideas please?
Laser pickup unit fault. Check and replace it. Contact any service technician. This is not an easy work that can be done by a user. http://electronicshelponline.blogspot.com/
SOURCE: Region code for Samsung DVD-V6700
1. Make sure there is no DVD in the drive. The player must be empty. Turn on the player, (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the USA ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 29334
SOURCE: I have a region 2 samsung dvd player. All of a
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
SOURCE: Samsung DVD (1500) Remote problem.
Can you please press the DVD button on the top of the Blu-Ray remote control then try to operate it whilst playing a DVD.
SOURCE: Cannot play this disc
1) Physical fault
use a blower and clean the internal parts by blowing
2) fault in the lense section of the player
may need a thorough cicute scan
I have the same problem with my dvd player, it also will continue to spin even after I turn off the power, and will then eject the disk.
