Panasonic DVD-RP82 DVD Player Logo
A
Anonymous Posted on Aug 24, 2012
Disc door will not open on panasonic sa-dm3 dvd/cd
matt martin
Level 3:
  • Panasonic Master 1,259 Answers
  • Posted on Nov 03, 2018
matt martin
Panasonic Master
Level 3:
Answers
1259
Questions
12
Helped
297216
Points
3635
You have a broken belt. Thanks for asking, Matt Martins TV Repair.
5 Related Answers
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Oct 01, 2008
SOURCE: Panasonic SA-HT680 DVD Home Theater
You need to disasemble and clean up very well all the parts,because it´s out of time.
Anonymous
  • 70 Answers
  • Posted on Oct 05, 2008
SOURCE: PANASONIC DVD-REC/VCR COMBO with Integrated Digital Tuner & HDMI-DMR-EZ47V playback
When you say downloaded movies are they avi's, vob's mpegs, mov's or windows media files? Which files are you using on the cds? what software are you using to burn the discs? When you burn onto cds are you creating VCD's or just data discs. When you burn onto a RW disc it cannot be finalised. I think you are possibly either not using mpegs or vobs or you discs are not being finalised. (When i say vobs i mean dvd compiled and compatible discs)
ravichetty
RAVI CHETTY
  • 158 Answers
  • Posted on Jul 20, 2009
SOURCE: No Disc
you need to replace the laser/optical
Jamie Andrew Knights
  • 244 Answers
  • Posted on Jul 23, 2009
SOURCE: ON A DVD-CV37 PANASONIC DVD/CD PLAYER KEEPS GIVING
This normally means the spindle motor is faulty.
Anonymous
  • 189 Answers
  • Posted on Aug 24, 2009
SOURCE: anyone know the all region codes for Panasonic SA-PT875 dvd
HELLO!
The main problem with Panasonic DVD units is they are locked to a certain region. The vast majority CANNOT be hacked via the remote control unit and please be warned there some websites who offer strings of codes (with many many numbers) and they are not guaranteed to work - in fact - some can screw up your machine for good.
My advice: take it to a local service centre who will unlock your machine properly!
GOOD LUCK!
Panasonic SA-DM3 shutting down issue
The amplifier is over heating. Probably the emitters, drivers and voltage regulator is bad. I suggest a clean sweep replacing the power pack integrated amp, all emitters, mosfet regulator, and SRC power switch start up control.
Panasonic sa-dm3, says setting error, change setting and the turns off. what can i do?
It is always wise to tell us if this is new equipment or a spontaneous failure on previously functioning equipment. I'm guessing this the former.
For starters you could look at the manual.
http://www.retrevo.com/support/Panasonic-SA-DM3-Home-Theater-Systems-manual/id/312ci674/t/2/
See page 5. >>>>>>>>>>>>>>> STEP 1 <<<<<<<<<<<<<<< - Orienting the unit and attach the feet.
Its physical orientation is wrong, possibly upside down.
My Panasonic SA-HT75 won't read any DVD/CD discs
The laser has failed. They all go this way. Throw it away and don't buy Panasonic next time.
Plays only cd's no dvd's reads no disc
The laser lens would have got repaired inside. Please change it.IT will read the dvds. It cost about 25$ i suppose
No Disc
Just ot a universal remote control just need the code from my panasonic dvd home thaerter sound system/sa-dm3
http://www.universal-remote.net/panasonic.html If they dont have it do a search on your comp for "panasonic dvd codes for universal remote" or something to that effect
1helpful
Does not play dvd disc or music disc
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
3answers
Hi folks!!!
Might be cheaper to pick-up a sub-woofer and a set of speakers at the local store. I checked e-bay..no luck, and it doesn't look like Panasonic will sell separates. It will be easy to get a color match.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
