Brother CS-8150 Computerized Sewing Machine Logo
Posted on Dec 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Moving needle from left to right with the zipper foot
I don't have the instruction manuel with me and I need to move the needle from the left to the right of the zipper foot to stich close to the edge. On the left it is too far from the foot. On the right it hits the center of the foot.
  • Anonymous Mar 24, 2014
    needle would not go on the side for zipper foot
  • Anonymous Apr 01, 2014
    Trying to sew a zipper, attached zipper foot, and cannot position the needle to the left or right. There is nothing in the manual.
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Jan 05, 2009
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
31993
Points
126
Here is a link to download your instruction manual for free if that helps?
Brother Sewing Machine Instruction Manuals
How to adjust needle from left to right using zipper foot on ELNA 7000 sewing machiene
The instruction manual should have that information. If you don't have one, you can get it here:
Elna Sewing Machine Instruction and Service Manuals
Machines either have a needle that will move right or left or the zipper presser foot will adjust right or left.
2answers
Using invisible zipper foot - needle hitting foot
We need to know the brand and model of your machine? Some zipper feet slide left or right. If yours does this, then you need to adjust the zipper foot so the needle doesn't hit.
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
2answers
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
2answers
I am trying to insert a zip. The needle is not moving far enough to the left or right so that it doesn't hit the zipper foot. Please help
try using a 1/2 foot as this will allow the needle to get close to the edge or zip
commonly used for making a rope edge
available from any sewing machine shop
1helpful
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Singer 7464
I don't have that machine but my needle moves when I touch the needle sign and use the + or - to move the needle to the left or right. Presser foot and needle must both be up.
Elna needle is not lining up with the zipper foot notches
You ought to be able to move the needle in increments from left to right. Check your manual or the Elna website for help.
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
