Change battery
SOURCE: Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
SOURCE: How do you chang the battery in a kenneth Cole KC
oPEN THE WATCH CASE BACK AND PUT THE NEW BATTERY IN.
SOURCE: How do I open Kenneth Cole watch KC 3567 to
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry store can change the battery and renew the gasket for you.
SOURCE: need repacement black rubber strap for kenneth
To find an international store go to following link:
http://www.kennethcole.com/content/index.jsp?page=intlstore&h=688&w=900
Or call 1-800-KEN-COLE
SOURCE: I have a Kenneth Cole
I have looked at the KC web site and most of the instructions don't give model numbers., so it is impossible to see if any of the instructions listed refer to your watch.
(if you go to http://www.genevawatchgroup.com/ , click on customer service and then scroll down,you will see KC instructions).
Isyour watch automatic? If it is, then it needs to be shaken (gently) from side to side for a minute or two to wind it up.
If it is a quartz type and you have pressed the winder into the home position and it still doesn't start, take it back and ask for a replacement.
