Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
Posted on Aug 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO SET ORIGINAL SIZE OF HDD SEGATE BARRACUDA ST380011A THAT I WAS SET TO LIMITED SIZE I.E. 32GB NOW I WANT SET IT TO 80GB WHICH IS ORIGINAL SIZE.
Brian Sullivan
Level 3:
  • Seagate Master 27,725 Answers
  • Posted on Aug 25, 2012
Brian Sullivan
Seagate Master
Level 3:
Answers
27725
Questions
Helped
5669073
Points
79191
Purchase or download a partition manager program.
The only way you can easily manage or change your partition size is to get a third-party program.
Partition Magic Freeware is the most widely known partition manager software. http://www.filehoo.com/download/Partition-Magic-8,0.aspx You can also download freeware programs such as Cute Partition Manager. http://download.cnet.com/cute-partition-manager/3000-2094_4-10605516.html
Open or run the partition manager.
In Partition Magic you can open the program easily. In Cute Partition Manager you may have to create a boot disk and boot from it to run the program. Once the program is open, select the drive you want to manage.
Go to the menu and choose an action or right-click and choose "resize." There will be an action -menu that will let you choose something like "resize" or "change hard drive size."
Some programs will also let you right-click on the graphical expression of a drive and choose the action or drag the graph to change the size.
Pick a new size for the drive and decide what you want to do with the remaining space. The rest of the space should be partitioned or formatted to make use of it if the current partition is downsized.
Apply the changes by clicking "apply" or "OK." You will then have to reboot the computer for the changes to take effect. The program may automatically do this for you or it simply may direct you to do it.
5 Related Answers
shaky120
John Anderson
  • 310 Answers
  • Posted on Jan 01, 2008
SOURCE: hard disk is not detecting
hi, you should try downloading this http://www.seagate.com/www/en-us/support/downloads/seatools/
and booting off the floppy disk it creates will tell you if theres a problem with the drive and will probably fix it for you..
Happy New Year
John
Anonymous
  • Posted on Mar 02, 2008
SOURCE: dead controller card on ST380011A
Hey man i strange prob in my Hdd Barracuda 7200.7, 80 Gb, ST380011A there is kinda sound coming from my hardisk like takk takk takkk n the n my pc cant catch it....plz plz plzzzzzzzzzz helpppppppp me i have alot of data in it ......
Pinky01
Elise Lacoursiere
  • 209 Answers
  • Posted on Nov 30, 2008
SOURCE: Barracuda st380011a controller pcb
For shansterbaby:
The first thing for the computer to find the drive is when it does the very first test on itself, at the POST. It detects all the components. You hear a bip. Then, you can see the result of the POST in the BIOS. If the HDrive is detected, you will find the st380011a in the list of the drive. Once you see the drive in the list, you're okay for the next step, to boot from Windows. Do you use Vista? or XP? For XP, I would open Windows Explorer and see under My Computer if you have another drive (D:, or E:). Click on it.
For meadomuffin, I had some problem with an Internal drive. I download for Seagate website a tool (it is called Seagate tool). I started a check disk from that tool, reformatted and it was then Okay to use it. Windows could detect it. Maybe that is not the answer for your problem. Let me know.
Anonymous
  • 121 Answers
  • Posted on Oct 08, 2009
SOURCE: i AM TRYING TO REPLACE SEGATE BARRACUDA 7200.7
If your u8 has an operating system installed, yes, you can do that.
Be sure to boot the u8 in Safe Mode to copy your files.
I would also recommend checking the copied files for viruses before you use them.
Testimonial: "good sound advice"
Anonymous
  • 111 Answers
  • Posted on Jun 28, 2010
SOURCE: my seagate barracuda 7200.7 st380011A 80gb
i think you must place a jumper on the back side of the hdd.
If there isn't any jumper, it is a "slave".
When you place a jumper on the correct spot, the hard drive will become the master hdd. The position of the jumper can be found on the hdd itself.
Search for "master" and put the jumper there
Is seagate Barracuda 7200.12 500 gb hard disk pc board is same as 350 segate board
They could be electronically and physically the same but I do not think the firmware is the same hence it will not work properly.
you could do it by reformatting your hard drive which would mean loading your operating system again during the formatting process you will be given the option to select a partition or to select another or resize or download some software either partition magic which enables you to rezize your your already partitioned hard drive without losing any of you data http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
4helpful
2answers
How can I convert a Seagate Barracuda 7200.7 (Model st380011a) to an external drive with usb?
BUY A HDD ENCLOSURE (http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=2777&name=Hard%20Drive%20Enclosures)
3helpful
My seagate barracuda 7200.7 st380011A 80gb when i use it as primary haerd dist operating system is not supporting it but when i use another hard disk as primary and it as secondary it is properly working....
1helpful
3answers
I AM TRYING TO REPLACE SEGATE BARRACUDA 7200.7 80GB HARD DRIVE WHICH IS VIRUS INFECTED WITH SEGATE U8 DRIVE TO GET THE COMPUTER RUNNING. iF i GET THE COMPUTER RUNNING THEN I PLAN TO PUT SEGATE BARRACUDA AS...
2answers
Hard disk is not detecting
Happy New Year
John
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
