Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
Jun del Posted on Apr 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My picture went dark but the audio is ok on Philips model 51pw9303
My picture went dark but the audio is ok. I turned it on/off and change channel from video mode. Now all I can hear is continous squicking sound. Please help
  • Jun del Apr 05, 2007
    Thanks for your response ...does any one know where I can find a shematic diagram for this model? Can anyone else give me specific technical answer like prevous experience in general model for projection tv w/ same problem. I read it could be covergence IC. also here is the squiking sound coming from. thx
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Apr 04, 2007
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336400
Points
2402
Your tv needs to be taken to tech i is having problem in the video and related circuit.or power supply.good luck
I have a Philips tv model 51PW9303 I hooked up a brand new Playstation 3 and there is no sound
if you used hdmi it may no support audio...in that case just run a pair of av cables for the auido out..
No picture. Sound is OK on Philips DPTV345 model 51PW9303/17F
I would check the solder on the Vertical output IC as ofetn the soolder will crack and the CRts will shut down to prevent damageing the CRts when vertical drops out. If the solder looks good I would try replaceing the vertical IC very inexpensive and you can get the vertical IC from www.tvrepairworld.com
I have Audio but no picture, happen no warning to
This just happened to me too .. I guess we're just gonna have to get a new TV? did you get any info?
Screen has green horizontal lines
could be the transformer due to the price you paid for the tv might be wothwhile having it replaced
Convergence off
The convergence board is bad. If the convergence board were still good, then the convergence menu would allow you to adjust the crosshairs.
2answers
No picture, screen is dark, but audio and the system control is operational
This sounds like the vertical output IC has stopped working. If the vertical pulses are missing at the yokes then the picture shuts down to protect the CRT's from being burned by the intense thin white line through the center of the picture. I have seen many of those TDA vertical output IC's fail.
Dark spot on the top of the screen
May you should have a replacement for that, seems is has a factory damage on it!
No Picture
The convergence IC's could be loading down the SMPS. Or it could have shorted a componet in the supply. if your not trained in solid state electronics, please seek out a repair shop to assist you with this repair. Good Luck
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
