It I think Happened when I restored my phone. But it was not the 1st time I restored. I've been using it for a year and its been all good.
SOURCE: i have nokia 3110c .. but i can't install opera mini software ...
You need to have a functional GPRS subscription too.
SOURCE: for jar files my mb. says file format is not supported !
Do you have the .jar supporter. For ex. for enablinh .rar file you need winrar. Like that do you have it. Please check it and reply.
SOURCE: Hi.. I cant open opera
hello friend,
First of all,you should download opera mini 5 from the internet.if you have Nokia 2690 with data cable then you can easily access internet on your computer.you can make your Nokia 2690 as a modem.how should you do this? i am giving you some tips as follows.please keep it up.
1) Open http://www.google.com
2) Type Opera mini for Nokia 2690 on Google search bar
3) Click on http://www.megamobilecontent.com/software/Nokia-2690/Opera-Mini-i16804/
4) Click on Opera Mini (5.1.21214) Download
After downloaded Opera Mini.jar file (size is 266kb) on your computer,
5) Open opera mini.jar file
6) if you have installed Nokia PC Suite then message appear:- Do you want to install the application to the phone?
7) Click on right tick button that is YES.
8) After installation, message comes,Installation complete.
9)Open your Nokia 2690
10) Click on Applications
11) Click on Collection
12) There at last you will find opera mini icon.
but before running it.i suggest you restart your mobile at once.now you can surf internet through opera mini 5 regularly basis.
Good Luck.
Thanks for using FixYa
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 2690 Flash File and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
