How do I hook it up to Netflix
The Emerson LC320EM2 is not a Smart TV. To display Netflix content, you can connect the TV to your computer via the VGA port on the TV. Then use the TV as your monitor; this may not work with HDCP content. To do this, turn off both the TV and the computer before connecting the devices. Then turn on the TV and set it to the VGA input (PC) before turning on the computer. (Note: you may have to enable the port in the BIOS on some laptops.) If your computer doesn't have a VGA port, try a DVI to VGA adapter. (This may not work with some video cards that only have digital signal output. Look at the port and make sure that the cable/adapter doesn't have more pins than the port.)
Alternatively, get a set top box with Netflix support. (Some Blu-ray players, the Roku box, Apple TV, or the WD Live Hub all have internet connection options and support Netflix. All will support a wired ethernet connection; some models will require a dongle to connect to a wifi network.)
Once you have the set top box, connect the TV to the box via a HDMI cable (purchased separately for most units). Connect to your internet connection and then log into Netflix, These steps will depend on the unit; please add a comment with your source of the Netflix content.
I hope this helps.
(I have an LG Smart TV; it is slow to find the wireless network when started. So expect some wait time before you can sign into Netflix.)
SOURCE: how do i connect my laptop to the Emerson 32
Connect the tv using a VGA cable, configure it as the second monitor in the laptop, open Netflix and then drag the window to the tv.
SOURCE: hooking computer up to tv to watch movie
Purchase a vga cable and hook it up to the computer and then to the tv
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
SOURCE: How do I hook up internet to my television so I
I assume you have your PS3 connected to the television and you can play games. For Netflix, you need to plug in an ethernet cable to the back of your PS3, be a Netflix member with at least a $9 monthly unlimited plan, and get a Netflix "Instant Streaming Disk" for PS3, which you can get for free (go to the account page and type "PS3" into the help box) once you are a member.
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
SOURCE: how can i delete a
To delete a Netflix account on your Panasonic TV you have to reset the settings/memory to factory defaults.
****WARNING**** all memory stored will be deleted take precautions to write down any desired settings or network information.
1. click menu
2. scroll down to setup(wrench icon)
3. scroll down to reset defaults
4. create a password
5. Reset all settings to default? click "yes"
6. Follow all directions to configure your television.
When you open Netflix via VieraCast your Netflix account should give you a code. Sign in from your computer and enter the code.
