1999 Isuzu Rodeo Logo
A
Anonymous Posted on Aug 23, 2012
Need to replace radio antenna on a 99 isuzu rodeo
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1426
Points
I just replaced the antenna on our 02 rodeo. No need to remove radio or anything in dash. This is how I did it.
First you will need access to back of fender, enough room for your hand. Open hood and remove 3 bolts running along top of fender, open passenger door and remove top bolt holding fender. Gently pry top of fender away from vehicle. Place object in gap to hold fender ( I used the head of a rubber mallet). Reach inside fender and disconnect old antenna, follow cable through wall into passenger compartment. Gently pull cable from behind carpet and unplug old antenna from coupler. Connect new antenna to fender ( replacement antenna I ordered was slightly smaller than opening so I had to add washer). Run new antenna cable through wall and plug into coupler. Re-attach fender
need to replace radio antenna on a 99 isuzu rodeo - 1_7_2013_12_53_34_pm.jpg
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Sep 29, 2008
SOURCE: replace the alternator on a 97 isuzu rodeo
from Yahoo answers
The alternator is located on the passenger side of the motor at the bottom. There is a bracket attached to the motor and the alternator. You need not take the bracket off to remove the alternator. Two bolts hold the alternator to the bracket. One bolt is on the front top of the alternator and one bolt is located on the bottom front of the alternator. The bottom front bolt is attached to the tension adjustment for the alternator. Loosen the tension screw then remove the bolt going through the tension adjustment. After you loosen the top, front bolt, the alternator should be loose enough to move side to side. Remove the top, front bolt. Now you must disconnect the alternator from the power supply. Behind the alternator is a screw with a wire attached via nut. Remove this wire. Nextly there is a series of wires with a plug on the end. It is plugged into the side of the alternator. Uplug this item. You can also access both of these from the passenger side front tire well. Something to consider is that remanufactured alternators in Rodeo's as well as the Honda Passport (which has the same engine as the Rodeo) do not work and the problem(s) associated with a bad alternator,ie; not charging, no fan blower, battery light and brake light on, still exsist after replacing alternator with reman. Use a factory original alternator if possible. It will cost a little more than a reman but will most likely save you a lot of time and headache!
Hope this helps you out!!
L
Anonymous
  • 4 Answers
  • Posted on Feb 22, 2009
SOURCE: timing settings for a 1998 isuzu rodeo
You didn't say whether you had a V6 engine or a 4cyl. Here is the procedure for a V6.
It sounds like he moved the cam shaft independently of the crankshaft or other camshaft so you will need to do all these procedures:
1. Turn the crankshaft until the mark on the spocket is lined up with the mark on the oil pump housing (the mark is on the driver's side at 90 degrees to the sprocket itself).
2. Back off the crankshaft counterclockwise 1/8 turn to ensure the pistons aren't at top dead center. This gives the valves room to move without hitting the piston.
3. Turn the passenger's side camshaft until it "jumps" into place with the alignment mark on the camshaft pully is pretty close to being lined up with the mark on the engine head.
4. Turn the driver's side camshaft until it "jumps" into place but this won't be perfectly lined up with the mark but will be about an 1/8 turn off from the mark. Then line it up by hand.
5. The idler pulleys and tensioner pulleys should be installed on the engine but the tenioner pulley adjuster (it is a little cylinder with a rod coming out of it that is held in place by 2 bolts) should be removed.
6. Place the new belt on the crankshaft first. Be sure the arrows on the belt point in a clockwise direction. If you have a belt with lines and dots then the lines will line up with all markings that you have lined up together. The dots should line up at the 270 degree point on the crankshaft (opposite of the lines and the markings).
7. Loop the belt around the tensioner pulley, around the passenger's side cam, under the waterpump, around the driver's side cam, and finally around the idler pulley. Check all alignments.
8. Put the tesioner adjuster in a vise and squeeze it together until you can place a small drill bit or allen wrench through the holes to keep it compressed.
9. This is the tricky part. You will need to install the tensioner adjuster and that will require some moving of the belt to allow enough play to get the adjuster in place. This may move the passenger's side alignment. If so, you will need to try it again. I find that if you move passenger's side alignment mark clockwise by one tooth of the sprocket, then when you go to put the tensioner in place it lines up. You may find other tricks to overcome this challenge.
10. Once you think you have everything lined up. Use a wrench to turn the crankshaft sprocket 2 full turns. Listen closely and feel for any hard resistance as you do this to determine if the pistons are hitting the valves. If you believe they are hitting each other thenrepeat the adjustment procedure. Not doing this can ruin the valves or more.
11. If everything seems OK. remove the drill bit or allen wrench from the tension adjuster. Perform step 10 again for one final check.
I hope this helps.
Anonymous
  • 319 Answers
  • Posted on Mar 19, 2009
SOURCE: where is air cabin filter located on 99 isuzu rodeo?
its usually behind the glove compartment in the blower box. you will have to pull the GB door down all the way to access it
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jul 03, 2009
SOURCE: water pump replacement 96 isuzu rodeo
Remove belt, fan, fan shroud and fan bracket. Remove timing covers, timing belt and water pump. Replace timing belt and the hydraulic tensioner with new ones. I suggest you get a mechanic to do this as you can easly get it out of time. Not an easy job.
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on May 20, 2010
SOURCE: need to know the timing marks for a 99 isuzu rodeo
Heres two diagrams for aligning the timing gears for timing belt, this is for a 1999 rodeo with the 3.2 engine, hope this helps,one diagram is for the cams and the other is for the crank gear,d5220b7.gif813ac66.gif
99 isuzu rodeo remote wont work
Flip the battery over and see if the remote will operate with that orientation. You could check the battery to make sure it works.
Also check the contacts. Can be cleaned with Q-tip lightly moistened with rubbing alcohol. (Don't overdo the alcohol, you don't want to wet anything except the contacts.) If there is corrosion, can be cleaned carefully with a pencil eraser or with fine sandpaper. Shake or blow out any debris.
Hope these thoughts help. Good luck
5helpful
Como poner banda del tiempo a una isuzu 99
COMO PONER BANDA DE TIEMPO DE UNA ISUZU RODEO 99
1helpful
Hearing ticking noise from my 1993 isuzu rodeo. Tried oil changes, additives etc. Need to know step by step instructions on replacing lifters.
I had same problem with 99 Isuzu Rodeo LS 3.2 V6. Dealer couldn't find it and many, many other owners experienced same thing. finally found a post where a mechanic (non dealer) changed the idle air control valve. so i tried it, and after 3 years of dealing with the problem, it worked!!! part costs about $40 and very, very easy to change yourself. for the 99, its located in front of engine, so easy access. Good Luck
2answers
What is the proper way to add a quart of engine oil to my 99 isuzu rodeo?
Open the oil filler cap, insert a funnel, pour oil into funnel until qt. bottle is empty, remove funnel and replace filler cap.
5helpful
3answers
Need wiring diagram for 1996 isuzu rodeo stereo
1996 Isuzu Rodeo Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Brown/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: 4′ x 6′
Car Audio Rear Speakers Location: Behind the Seat
Left Rear Speaker Positive Wire (+): Orange
Left Rear Speaker Negative Wire (-): White
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Orange/White
Checked fault memory code po342
if its V6 it is in rear left head next to inlet manifold
plug must face rear of vehicle
I need a diagram for installing a radio with out a wirering harness
Have fun.
1995 Isuzu Rodeo Stereo Wiring Constant 12V+ Red/White Switched 12V+ Brown/White Ground Black Illumination Green/Red Dimmer n/a Antenna Right Front Front Speakers 4" Dash Left Front (+) Blue/Yellow Left Front (-) Yellow Right Front (+) Green/White Right Front (-) Gray/White Rear Speakers 4" Side Panels Left Rear (+) White Left Rear (-) Red/White Right Rear (+) Orange Right Rear (-) Black/Orange
2helpful
Radio installation
2answers
99 Isuzu Rodeo 3.2L 2wd Catalytic Converter instructions
you're having the same problem i had with my 99 isuzu rodeo 2 wd 3.2 i paid a muffler guy over $600 to replace those catalytic converters, if you're good at welding you could do the welding yourself after buying the catalytics, basiclly i seen them just cut them off and welded them back on
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
