Phone is set to auto update for date and time. The battery is 10 months old.
SOURCE: Need to change the phone number on for my Motorola RAZR V3
Yes, that is exactly what it is. Both phones are at&t, therefore all u would have to do is change the sim card. If one was a different carrier, then it would get a little more complicated and you would need to unlock the device.
SOURCE: Motorola RAZR V3i Cellular Phone set the time/date
the best info that i can provide is to download ur user manual.
after that search for time and date in the PDF.
quote form nanual:
time & date
Your phone uses the time and date for the
Datebook.
To synchronize the time and date with
the network: Press a >wSettings
> Initial Setup > Time and Date > Autoupdate
> On.
To manually set the time and date, turn off
Autoupdate, then: Press a >wSettings
> Initial Setup > Time and Date > Time and Date.
manual
http://www.motorola.com/mdirect/manuals/V3i_9504A48O.pdf
plz give
SOURCE: Changing the time on my Motorola Razr V3 phone
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
SOURCE: My Motorola Razr v3 cell phone's lcd is blank
Sounds like your backlight went out. It happens every now and then on lcd screens.
you must first disable Autoupdate (turn it off) - go to settings>scroll to Initial Setup, (select this)>Time & Date (select this)>Autoupdate (set to OFF)>after you do this option will appear to change time to 12/24 hour....
