Dewalt Generator. 6000 Watt Portable Generator with Honda Engine Logo
shahid Posted on Aug 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generator does not start
New battery, full of gas, turns over but does not start. Not used for over 6 months. Tank was empty.
Anonymous
Level 2:
New Friend:
  • Expert 97 Answers
  • Posted on Aug 23, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
97
Questions
0
Helped
29526
Points
269
The float bowl their is a drain bolt, take it out check for gas.
Generator does not start it has fuel in the tank with new battery ,check every thing is ok
how OLD is the gas? if it is older than 3 months with NO stab condishner get rid of it try new gas
Generac GP5000 will turn over but will not start, If I spray start spray it turns over for a few seconds and stops. someone told me to use sea foam because it had been un-used for about 6 monhs. Ccould...
FRIST O FALL CHECK TO SEE IF THERE IS A SHUT OFF VAULVE UNDER THE GAS TANK SEE IF THIS IS OPEN ALSO HOW OLD IS THE GAS , DONT LEAVE GAS IN THE GAS TANK THE GAS TODAY DOES NOT HAVE BUT A MONTH OF SHELF LIFE. YOU MAY HAVE TO PULL THE CARB DOWN AND CLEAN THE BOWL AND THE JETS IN THE CARB ALSO START BY PUTTING FRESH GAS IN THE TANK
1helpful
Generator trouble starting and running rough
ok simple things first, new spark plug, fresh gas, a decent dose of fuel cleaner a bottle doses 12 gallons so say if 3 gallons gas use 1/4 bottle (yes double dose wont hurt) , air filter, try running this first and see if it picks up over time, the methanol gas really crude's up small engines and the cleaner will hopefully clear it up, use fuel stabilizer with ethanol protection and dont let tank sit empty always full to keep moisture to lowest level. if this doesnt work then likely carb is fouled and needs rebuild
Jun 03, 2012 • Hammering
3helpful
My pro user g5000 generator wonts start after being stood for 6 months any ideas
Hello John, Your gas more than likely has gone bad. If you have spark and good compression and it won't start then chances are the gas has gone bad. Today's gas contains about 10% ethanol, which is absolutely terrible for small engines. Gas with ethanol has a max shelf life of about 90 days under perfect conditions. A month or less is more realistic. Here is the problem, ethanol absorbs water and sits at the bottom of the tank in the generator. If You have a 5 gallon tank With 10% ethanol then 10% times 5 gallons equals half a gallon of water saturated ethanol sitting at the bottom of the tank, I don't care what kind or how good an engine it is, it won't run on water saturated alcohol. Here is a great video explaining it. http://www.youtube.com/watch?v=YeCyFxoWPpo So what I would suggest is to drain the tank and the carburetor bowl of all the old gas. Replace the bowl and check for leaks. While everything is empty I would suggest that you replace the fuel line with a Tygon line. Tygon is resistant to ethanol. I would also ad a see through inline fuel filter and a new spark plug. After this is all done, put in a small amount of gas, less then a half gallon and see if she fires up. If it fires up right away you should be all good to go. Let the generator run until it's completely empty. And store it empty. Here are some problems and solutions that I have for gas with ethanol. I live in Savannah Georgia and the high humidity during the summer can ruin the gas in my lawn tractor in less than 2 weeks due to water saturation. The tractor is almost impossible to start and runs terribly until the remaining gas is used up. I have stopped filling the tank completely and I use just enough gas to cut the lawn then I store the tractor almost empty. I also use gas cans made by a company called Blitz. These containers are pretty much airtight and do not allow the ethanol to absorb water. This has made a tremendous difference in engine performance. Another thing that you can do is to check out this website http://pure-gas.org/ If you are lucky , you might have a gas station that sells gasoline without any ethanol added. This type of gas has a much longer shelf life and if a product like Stabil is added, you might get over a year of safe storage of gas for your generator. Municipal airports have banned ethanol in aviation gas and so have most marina's. It might cost a little more but it sure is worth it when the lights go out. If you can't find pure gas then I suggest you store gas in the Blitz containers for about 3 to 4 months. If you don't need to use the generator then use the gas in your car and refill the Blitz tanks again. Better safe than sorry. I hope this helps and if it does would you please be so kind and give me a positive rating for my solution. Good luck and thank you, Michael Burke.
Engine surges
Hi Johnny,
I think the heart of your problem lies with the ethanol content in today's gas. It has at the very least 10%. The problem with gas containing ethanol, it only has a shelf life of about 30 days. What happens is the ethanol absorbs water from moisture in the air. The ethanol and water bond together and have a higher density than the petroleum based gas on top. It is exactly like oil floating on water. When this happens the octane rating of your gas drops dramatically, that's problem number one. Problem number 2, let's say your generator has a 10 gallon tank. Each gallon containing 10% ethanol, 1/10th of a gallon times 10. After about a month or two in a humid area you have a full gallon of water and ethanol sitting on the bottom of your tank. The best generator in the world will not run properly with this garbage sitting at the bottom. Problem number 3 ethanol is a strong solvent, it will deteriorate your fuel line. It will gum up the inside and make the exterior brittle. I would strongly suggest that you replace the fuel line with Tygon or any other ethanol safe fuel line and replace or install an inline fuel filter.Check out the website pure-gas.org to see if ethanol free gas is available in your area. Here are two products that I strongly recommend Sea Foam and Sea Foam Deep Creep. I would completely drain the tank on your generator, install the new fuel line, spray a liberal amount of Deep Creep into the fuel line and let it sit for about an hour. Then drain the fuel bowl, fill the fuel line again with Deep Creep and let it sit for a little while. With the fuel bowl off, you should be able to lift the float and have smooth action with the float pin, no sticking the Deep Creep should flow smoothly when the float is lifted, after this is done re-assemble the carburetor and attach the fuel line to the tank. Add enough gas to run the generator for about 20 minutes and then use the Sea Foam. I have had stunning results from Sea Foam, I am not affiliated with this product it just works great and that is why I recommend it so strongly. Try to get the spray can of Sea Foam because that will be the easiest way to get it into the carburetor while it is running. Bring the generator outdoors after you have added a little gas to the tank remove the air filter from the carburetor and start the engine. Spray the Sea Foam directly into the carburetor, do not spray so much that it stalls the engine. After a spray or two you will get a feel for how much you can spray without stalling. Now the fun begins. Sea Foam removes carbon fouling from the engine and cleans the jets in the carburetor and it does this incredibly well but it produces an amazing amount of smoke, this can be very alarming at first but do not worry this is absolutely normal. You will be stunned by how much carbon gets burned out. Close the windows in your house and tell your neighbors in advance so they don't call the fire department. There will be that much smoke. Intermittently spray and let the fouling burn out. Do this about four to five times then spray a bit in the gas tank and let the generator run until it is empty. After the generator is empty add a little Sea Foam to the crank case oil, read the can for the proper amount. Store the generator empty. Sea Foam has stopped valve tapping, erratic float problems, rough idles and hard starting issues for me, It is an amazing product. I know that the desire to have a full tank in the generator for when the power goes out is very strong but it will cause you nothing but grief in the long run. You are better off finding gas cans that are air tight, they will not allow moisture to be absorbed into the ethanol and you will have a much longer shelf life. When the power comes back on I use a kerosene pump to empty my generator and then I run the engine dry.By using this method I have an extremely dependable machine that starts on the first pull every time even after sitting for over a year.Sorry for being so long winded but this is what really works and for those that also read this post who are not mechanically inclined, the long winded explanation gives them a clearer idea on how to solve this problem. Good Luck,Michael Burke
6helpful
3answers
Gas gauge is not reading correctly. Shows a full
the problem is caused by a defective gas gauge sending unit, this part is located inside the gas tank, you must remove the gas tank to replace it.
Onda generator engine starts and then 3 or 4 seconds later stall
Oil pressure switch. Check it and make sure oil level is correct. The oil switch will cause this
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
2helpful
4answers
Looking for manual for generator...won't start
I had the exact same problem. There a few things you need to do first.
1) Make sure the fuel line knob is turned to the Open position; this knob is located under the gas tank.
2) Turn the power switch to on : it is a little red switch located near the pull-handle on the front of the generator. It needs to be on 'I' not on 'O'
3) Turn the choke lever on: it is a little steel lever with an arrow at the tip. Move the lever in the direction the arrow is pointing.
4) Make sure you have gas left in the tank: it may have evaporated or gummed up if you did mix in a fuel stabilizer before putting it away for storage.
If none of these things work , then you carburator may be full of water and gas lines gummed up.
These Gens need to be started up at least once a month to make sure they keep working properly.
Fred
1993 sentra jerking problems.
I wanted to just give a suggestion...do you go to the same gas station to get gas? My sentra ran horrible because I kept going to this same gas station. My gas would get low and it would start cutting off and trying to cut off. I let my fuel go to almost empty and then went to another gas station to fill up. It hasnt cut of for about 6 months now and I havent returned to that gas station.
Top Dewalt Electrical Supplies Experts
Stan Ford
CJ Rock
CJ Rock
Al Taqah Al Sareeah...
Level 1 Expert
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
