Infinite switch issue so need to change out one switch. I can't seem to figure out how to get the front panel off to gain access to the switch. I took off the 4 screws under the front control panel and now it is partially loose but not able to come off. I don't want to break the glass cooktop so am looking for help on what I need to do to remove the panel and gain access to the switches. Thanks
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Hello
& Welcome to FixYa
Please
view this video to follow the step by step instructions in order to replace the
infinite switch in your GE Gas range:
Please
get back to me if you have any other questions.
Kevin
