Anonymous Posted on Aug 23, 2012
Scanner driver for win7
I upgraded my system from Xp to Win7, so I need to driver my scanner. Model no: 2400CU+ Thanks
Scan Aid
Level 2:
Novelist:
  • Expert 104 Answers
  • Posted on Aug 24, 2012
Scan Aid
Expert
Level 2:
Novelist:
Answers
104
Questions
Helped
127377
Points
181
Please click the following link to download Mustek Bearpaw 2400 CU Plus Win 7 driver:
ftp://ftp.mustek.com.tw/pub/driver/BearPaw/2400CUPLUS/Vista32-64-XP-Windows7-32-64/setup.exe\
For more information, please visit the following link:
http://www.mustek.com.tw/Support/
Hope the above information is helpful.
regards,
ScanCare
[email protected]
Wenn I try to install programm "setup_full_5590_3.exe" on my Win7 64 PC, while I have ScanJet 5590, it stay evig in step 2 of setup "Preparing system for Installation", so I must...
Dear Davor, You are installing the software in Win 7. I think you are using the driver provided for win XP. If I am correct, than the driver cann't run in win7. So download the driver from net (go to hp site/ support and type your model No.) for win7 and install. it will work. thanks.
My Plustek optic pro st 19 scanner is not compatible with Microsoft windows 7 ultimate program..where can i get a free download of the driver?
This is an old scanner, no Win7 driver has been made for it by Plustek. You will have to buy a new scanner or install XP Mode in Win7 and load the scanner in it.
I have a microtek i320 scanner I used with win XP Since upgrading to Win 7 it no longer works. How can I upgrade my driver? Can I buy the proper driver without buying a whole new scanner?
This scanner should work with the XP 32-bit driver. The driver is here: http://support.microtek.com/knowledgebase_1/kbdtl.phtml?request=KB-00106SW . See the link for other scanners. Unplug the data cable, uninstall the scanner if it has a yellow triangle with an exclamation point, then install the driver. After installation, connect the data cable.
The support site for this scanner is here: http://support.microtek.com/product_dtl_2.phtml?prod_id=34 . This information is given in the Knowledge Base section if the other link doesn't work.
I know this will work with Win7 32-bit. I'm not sure about the 64-bit version. If the 64-bit version doesn't work with the above driver, you can either replace the scanner, use it with another computer with an older version of Windows, run a dual boot system with an older version of Windows and install the scanner only on that system, or run a virtual computer with an older version of Windows.
If you have Win7 Pro or Ultimate, you can do the virtual computer for free. Download and install Microsoft's Virtual PC and XP mode. Install the scanner in XP mode as you would on any XP computer. The only restriction is that the files may need to be saved to external media to share them between the two computers.
All other options will require a licensed version of the older Windows OS. (Virtual computer packages include VMWare and Parallels in addition to Virtual PC.)
I hope this helps.
(I have an older scanner that runs nicely with Win7 32-bit.)
2answers
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
I have a CanoScan LiDE80 that wont work now with my new operating system, Windows 7...when trying to install it.. says I need drivers but can't find compatiable one??? Any suggestions as I love this...
Do you have Win7 32-bit or 64-bit? If you have the 32-bit, the driver you need is here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . This driver works for Win2K-Win7. This is an unsigned driver and probably will not work in Win7 64-bit.
In my experience, Canon is very poor at supporting their scanners for 64-bit OS versions. In fact, they do not have a Vista 64-bit compatible version of the drivers for this scanner.
The only solutions I have found are tedious. 1) Keep your old computer that works with the scanner and transfer files on a USB drive or optical disc (RW is better for this). 2) Set up a virtual computer with an OS that works with the scanner. If you have Win7 Pro or Ultimate, you can do this for free. Download Microsoft's Virtual PC and the XP mode package. Install both in order. For other versions of Win7, you will need a virtualization program (Parallels, Virtual PC, VMWare) and a licensed version of XP (or other OS that will work with the scanner). Set up the virtual computer program and install the OS.
Next install your scanner to the virtual computer and use it in that "machine". You may need to transfer files to external or optical media to share the documents. You can't install a printer on both the virtual computer and the real computer at the same time (at least with XP mode).
I hope this helps.
(I tried using the compatibility mode and accepting the unsigned driver for a Win7 Home Premium 64-bit machine for a different Canon scanner. It didn't work and I have dealt with a number of old hardware and new OS issues over time.)
I need a driver for lide80 canoscan scanner
What OS do you have? The drivers (supported OS versions) for the LiDe 80 are available here: http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . If you have Win7 64-bit, the Vista x64 driver doesn't work even in the compatibility mode.
If you want a work-around for the 64-bit OS, Win7 Pro and Ultimate allow you to download and install XP mode free. This takes two programs, Virtual PC and the XP mode, that you download from Microsoft and install. This will run a virtual computer under Win7 and you can install the scanner to the virtual computer. To share files with the real computer, you should store them on external media.
Alternatively for Win7x64, you can install any of the other Virtual computer programs (Parallels, VMWare, etc) with a licensed older version of Windows. Then do the same as above. Another option is a dual boot computer with the older licensed version of Windows with the scanner installed to the "machine" with the older OS. I don't see a Unix driver for this scanner so you need a valid copy of Windows.
I hope this helps.
(If you have Win7 x64, the only other options are 1) to try and get Canon to extend their drivers (since they do support Win7 32-bit) or 2) get a new scanner.)
3helpful
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
Looking for a driver for epson gt 7000 scanner for windows 7.thanks
I do not see this scanner on the Epson support site. They may not have a Win7 driver. You could try an XP driver in the compatability mode (right click on the driver and select Properties and the Compatability tab. Check the box next to Run in compatability mode) You can download a driver from a site like this one, http://download.cnet.com/EPSON-GT-7000/3000-2118_4-73143.html .
Another possibility is available in Win7 Pro and Ultimate. Download and install the XP mode from Microsoft. Install the scanner in the virtual XP computer. You may need to save files to external media to transfer them between the two computers.
I hope this helps.
Upgraded to windows 7, need new driver for mustek 1200UB
check here http://www.mustek.com.tw/Download/driv_scanr/europe/1200ub.html
there doesn't appear to be one for win7. I thought there was an option to run win7 in xp mode to get around this problem.
Win7 or Vista 64 bit drivers for ArtixScan 4000tf
Microtek only supply drivers up to XP for this scanner.
k24674
ADMIN Andrew
ADMIN Andrew
