Cobra 29 LTD CB Radio Logo
Posted on Dec 20, 2008
Cobra 29 LTD Classic not transmitting or receiving
I just bought and installed a Cobra 29 LTD Classic with a Firestik 2 (4') antenna on a 99 Dodge 2500. I mounted the antenna on my alunimum toolbox on the passenger side. I did ground the toolbox to the pickup. The radio turns on fine and everything apperas to be fine but the ANT light does not light up. I used good coax cable and it is not grounded out anywhere. I cant transmit or receive, I can hear nothing at all. Is this a antenna mounting problem? Thanks for any information. Does not transmit or receive.
  • Anonymous Mar 31, 2014
    I have two Cobra 29 LTD Classics and neither one will receive. they do Transmit. Is there a way to test the speakers to see if this is the problem or something deeper ?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2117
Points
Ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
1 Related Answer
Anonymous
  • Posted on Jan 07, 2009
SOURCE: Cobra 29 LTD Classic not transmitting or receiving
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
How to wire a Sadelta M3 to a Cobra 29 LTD Classic
I believe to wire a Sadelta M3 microphone to a Cobra 29 LTD Classic CB radio:
The Sadelta M3 microphone has four wires: white, shield (bare wire), red, and black. The Cobra 29 LTD Classic CB radio's microphone jack also has four pins: Pin 1 (Audio), Pin 2 (Ground), Pin 3 (Transmit), and Pin 4 (Receive).
To wire the Sadelta M3 to the Cobra 29 LTD Classic, you need to connect each wire from the microphone to its corresponding pin on the microphone jack. The white wire carries the audio signal from the microphone's element to the radio, the shield wire provides a ground connection, the red wire activates the radio's transmit function when the microphone is keyed, and the black wire is used for receive audio.
Here are the specific steps to follow:
  1. Cut off the existing microphone plug on the Sadelta M3 microphone cord.
  2. Strip about 1/4 inch of insulation from each of the four wires in the Sadelta M3 microphone cord.
  3. Connect the wires to the pins on the microphone jack as follows:
  • White wire to Pin 1 (Audio)
  • Shield (bare wire) to Pin 2 (Ground)
  • Red wire to Pin 3 (Transmit)
  • Black wire to Pin 4 (Receive)
  1. Solder each wire to its corresponding pin on the microphone jack. You may want to use a multimeter to verify that each connection is solid and that there are no shorts or open circuits.
  2. Once you have soldered all the wires, test the microphone by speaking into it and checking that the radio's TX meter moves as you speak. Also, check that you can hear audio through the radio's speaker when receiving signals.
  3. If the microphone is working correctly, use heat shrink tubing or electrical tape to cover the soldered connections and provide strain relief for the wires.
Note that some microphones, including the Sadelta M3, may have additional features such as a built-in amplifier or power supply that require additional wiring.
1helpful
Cobra 29 ltd classic year 2004. rf gain problems.
Put SWR meter between your antenna and output, test wave length receive/transmit, might need a ground plane or center loaded stick.
Could be transceiver relay, try clicking mic fast, it should click out as fast as you key the mic.
When it's dry, I can't transmit, but when my antennas get wet,transmission doubles, WHY????
Hi John:
Try checking where the antenna is connected to the cable.
It may be corroded and you're not getting continuity unless it is wet.
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
www.americanradiohistory.com/Archive-Radio.../90s/.../EN-1993-11.pdf
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange www.experts-exchange.com > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42https://www.youtube.com/watch?v=vJle8vlsWLcAug 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixithttps://www.ifixit.com/.../Cobra_29_LTD_Classic_TroubleshootingiFixitCobra 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
2answers
Cobra 29 now Ltd classic Cobra 29 nw.ltd classic receives not well but does not transmit don't even move the swr./power meter any ideas
High SWR on antenna system.. may have mess up your RF final transistors. if you were talking on it for a long time. have someone check the SWR on the antenna system... should be a FREE service.
2helpful
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
1helpful
Bought a new cobra 29, need antenna advice
Firestik Dual CB Antenna Kit This is a most popular dual antenna kit and one we HIGHLY recommend! It contains everything you need and features premium USA-made components from Firestik. The included FS CB antennas are our best-selling antennas and ensure you'll receive maximum transmit and receive performance. Designed for the elements, the stainless steel springs and mounts are rust- and weather-resistant. The included three-way mounts -- the most popular style we carry-- offer numerous mounting possibilities.
I have just bought a cobra 29 ltd classic with a scanner ant and it worked befor on the turck it was on but now that iv installed it on my truck im not able to talk to other nor hear them
sounds like a mic problem if a wire is broken in the mic it will not let you receive or transmit common..or not to common an audio chip...
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
