I had set a particular password which it is not accepting now
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: how to unlock Htc Touch Diamond !!
follow my shared experience to ulock HTC Touch Diamond. Was locked with Orange operator in UK
http://internetbisnisonline.co.cc
over at xda forum the scumbags are charging people for the unlock software i got free from a german friend. this definatly unlocks htc touch, diamond, pro exc its really tricky to excute the last stepsbut it definatly works. all you need to do is join this site free and search for diamond_unlocker or browse through our ppc setion you will find it as i said its free of charge to join and download instructions are very easy to follow after you have completed steps 1-3 you need to flash a new radio. http://www.extremplanet.co.cc/forum/
SOURCE: htc touch diamond vibrate problems
The instruction given in the user's guide are WRONG, which infuriated me. To perform a hard reset, hold down the power button and turn the phone off. Then, while holding volume down and the center button, turn the phone back on. It will give you the hard reset prompt immediately. Follow the instructions. I hope I saved you the stress I went through.
SOURCE: My HTC Diamond Touch Screen wont work
you can try to recalibrate the touch screen to see if that works,
Start> settings> display> calibrate
* since screen is not working you will have to go the long away and use buttons on phone and nav wheel to get to these options
SOURCE: where do I find the device code on a HTC Touch Diamond?
All numbers are under the battery. take the back off and take out the battery
