Was watching tv and the picture just went black , i could still hear sound. turned off tv and turned int back on but did not see the viera bottom bar come up like normal. the power light just shows red like normal.. tv is only like 2 months old.
SOURCE: Screen just split in half
Is the tv still in warranty? The problem is the upper buffer board, it's a small board that controls the upper portion of the screen. You will have to consult a service center to get it, it's very easy to install
SOURCE: Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
SOURCE: We had a vertical line about 2 inches wide and
It is either the plasma panel itself or a connection problem, either way it will need to get serviced. Suggest you find receipt and phone Panasonic.
Cheers.
SOURCE: My Panasonic Viera 42" Plasma,
Typically this means you've got a power supply that went bad. I've been doing research for a potential class action lawsuit on these "blinking lights of death" problems that the Panasonics are having and that is usually why the tv will show 10 blinks. Occasionally another component inside the tv can be what caused the tv to shutdown and show the 10 blinks.
I'd like to hear more about your experience with the television and any contact you've had with Panasonic in an attempt to get the television repaired. If you're inclined to share your story with me, please contact me at [email protected].
