Coby Expert
- Posted on Sep 26, 2012
Re: How Do I Get Past a Pattern Lock MID8024
- Turn off the unit.
- Plug the unit into an electrical outlet.
- Take a microSD card out of the slot. (Empty the microSD card slot.)
- Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
- Release both buttons once the phrase "upgrade system activated" appears on the screen.
- Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
- Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
- Wait until it finishes making a partition and shut down the system automatically.
- Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
