My wife stepped on the treadmill and pressed start like normal. the console showed that it should be running at 1.0mph but the belt/track was not moving. The incline operates as normal and everything else appears to be fine except the track doesn't move. I unplugged the unit and thought it may reset, then pressing start the track moved briefly then stopped again. Console still shows that the track should be moving.
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
sincerely. Please keep me in touch.
