RCA HD52W59 HDTV Projection Television Logo
Posted on Jun 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hd52w59 I thought I e-mailed you last Sunday but I don't find anything. Okay, here is the deal my husband replaced the fuse for the 5th time and this time he soldered the flyback, last Friday. Worked all weekend went to put the cover back on Sunday afternoon. And it started doing it thing of kicking off and on with no picture. We tried resoldering the flyback again and we still can't get any power. Please help I just hate to ditch this TV. It has to be fixable. I'm not willing to give up.
Level 3:
Top Expert:
  • RCA Master 76,851 Answers
  • Posted on Jun 13, 2017
RCA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006483
Points
237762
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
1 Related Answer
Anonymous
  • 1030 Answers
  • Posted on Dec 29, 2008
SOURCE: hd52w59 - Me again....
sorry havent got back got some personal issue going on. So its cycling off. my fist instinct is to check the ribbion cables that go between boards. and most connectors. theres a cable that runs from the back green booard to the front center crt board in the front. this could be a problem. does the set make any noises?
1helpful
Hd52w59 - Me again....
Flyback
You can substitute a 1 amp PICO (pronounced peeko) fuse and it will work just fine. You should be able to order them anywhere. Let me know if I can be of further assistance
Okay let me know what you think
the flyback transformer is the large black component simalar looking to a disrtibitor of a car it has a large red wire coming out of top and a black wire. On the bottom of the board it has about 10 pins arranged in a circle. this is flyback is located adjacent to the fuse.
RCA HD52W59 wave
OK those are the correct fuses one in middle does cause lost of convergence FL231,recheck second ribbon connector, make sure it is in correctly also ck cp 150 it will be a green and gold writing on capacitor 2200uf 16v ,see if it is bubbled on top if so replace it and 2 other caps 220uf 35v,what you are saying about it waving could be a big capacitor on small AC board where ac fuse and cord plugs into ck them .Let me know if you need more help . Resolder all connection pinns on flyback.
Convergence
you need to have the conversion chips replaced , this is a pretty common repair and i would say it is definately worth the fix, some repair shops will come and fix it within a half hour to an hour depending on the difficulty in taking out the old part and or putting in the new
Star Mail
Do you have access to the programming of the voicemail ? If you do then you need to change the date and time on the voicemail system. The newer systems actually get the time and date from the phone system but the older ones did not. Let me know and I will try to find a manual for the Star Mail and walk you through the change. Power hits do strange things to phone systems, you never know what will be popping up after the hit. Good Luck. ..Mike
RCA HD52W59
check the fuse its located on the small rectangle board which is on the right side looking in the back its the board closet to where the screen is.
Olypus digital camera FE-240 7.1 megapixel
ok i think u cant do anything for that problem bec still under warranty?
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
