Need to know where to set wheels for highest cut for lawn
Move the 4 wheel adjustment levers to the number 4 position which is all the way forward (towards you if facing the front of the mower) and that is the highest setting which is about 4" cut height. Each number for the lever position represents the inches in cut. In between numbers is 1/2" so in between 2 and 3 would be 2 1/2" cut as an example.
SOURCE: front wheels of our riding lawn mower
Most front ends for riding lawn mowers, need to be greased. In addition to this, most of the rims for the front tires, have a nipple for a grease gun, which also need to be lubricated.
SOURCE: riding lawn mower runs but when engaged it
You need to check the belt on the deck. Something is binding or stuck. Could be a frozen pulley. Could also be the kill switch under the seat. If it is free, go get it.
SOURCE: on a Poulan Riding mower, there is a
lift seat remove battery & battery box acid from batt acid ate spring into should still be attached to hydro trammison
SOURCE: My 48
You will have to find another way to highten the deck, different bolts, shorter springs, Or if possible, adjusting the lever
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
